opsi-script reference card (4.12.13)
For Windows [W], Linux [L] and MacOS [M]
Global text constants
System directories
System directories [W]:
%ProgramFilesDir%: 'c:\program files (x86)' at 64 Bit
%ProgramFiles32Dir%: 'c:\Program Files (x86)' at 64 Bit //since 4.10.8
%ProgramFiles64Dir%: 'c:\program files' at 64 Bit //since 4.10.8
%ProgramFilesSysnativeDir% : 'c:\program files' at 64 Bit //since 4.10.8
%Systemroot% : 'c:\windows'
%System% : 'c:\windows\system32' at 32/64 Bit
%Systemdrive% : 'c:'
%ProfileDir% :
NT5: 'c:\Documents and Settings'
NT6: 'C:\users'
Common (AllUsers) directories [W]:
%AllUsersProfileDir% or %CommonProfileDir% :
NT5: 'c:\Documents and Settings\All Users'
NT6: 'C:\Users\Public'
%CommonStartMenuPath% or %CommonStartmenuDir% :
NT5: 'c:\Documents and Settings\All Users\Startmenu'
NT6: 'C:\ProgramData\Microsoft\Windows\Start Menu'
%CommonAppdataDir% :
NT5: 'c:\Documents and Settings\All Users\Application Data'
NT6: 'C:\ProgramData'
%CommonDesktopDir%
NT5: 'c:\Documents and Settings\All Users\Desktop'
NT6: 'C:\Users\Public\Desktop'
%CommonStartupDir%
NT5: 'c:\Documents and Settings\All Users\Autostart'
NT6: 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp'
%CommonProgramsDir%
NT6: 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs'
see also : Common (AllUsers) directories [W]
Default User directories [W]:
%DefaultUserProfileDir%: 'C:\Users\Default' //since 4.11.1.1
see also : Default User Directory [W]
Current user directories [W]:
User is the logged in user or given by /usercontext.
%AppdataDir% or %CurrentAppdataDir% : //since 4.10.8.13
NT6: 'c:\Users\%USERNAME%\Appdata\Roaming'
%CurrentStartmenuDir% //since 4.10.8.13
'C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\Start Menu'
%CurrentDesktopDir% //since 4.10.8.13
'C:\Users\<user name>\Desktop'
%CurrentStartupDir% //since 4.10.8.13
'C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup'
%CurrentProgramsDir% //since 4.10.8.13
'C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs'
%CurrentSendToDir% //since 4.10.8.13
'C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\SendTo'
%CurrentProfileDir% //since 4.11.2.1
'C:\Users\<user name>'
/AllUserProfiles directory constants [W/L/M]:
%UserProfileDir%
or
%CurrentProfileDir% // since 4.11.2.1
NT5: 'c:\Documents and Settings\%USERNAME%'
NT6: 'c:\users\%USERNAME%'
opsi-script Path and Directories [W/L/M]:
%ScriptPath% or %ScriptDir%
%RealScriptPath% (since 4.12.4.21)
%ScriptDrive%
%OpsiscriptDir% (since 4.12.3.6), %WinstDir%
%OpsiscriptVersion% (since 4.12.3.6), %WinstVersion% (since 4.10.8.3)
%opsiscriptProcname% (since 4.12.4.35)
%Logfile%
%opsiScriptHelperPath% '%ProgramFiles32Dir%\opsi.org\opsiScriptHelper\lib' // since 4.11.3.2
%opsiTmpDir% : 'c:\opsi.org\tmp' // since 4.11.4.3
%opsiUserTmpDir% : 'c:\opsi.org\usertmp' // since 4.12.4.37
%opsiLogDir% : 'c:\opsi.org\log' // since 4.11.4.3
%opsidata% : 'c:\opsi.org\data' // since 4.12.0.12
%opsiapplog% : 'c:\opsi.org\applog' // since 4.12.0.12
see also : opsi-script Path and Directory [W/L/M]
Network informations [W/L/M]:
%Host% : value of environment variable HOST.
%PCName%: value of environment variable PCNAME, or if absent of COMPUTERNAME.
%Username% : Name of actual user.
%IPName% : The dns name of the pc. Usually identical with the netbios name and therefore with %PCName% besides that the netbios names uses to be uppercase.
%IPAddress% : may be the IP-Address of the machine. Use funktion GetMyIpByTarget() instead.
see also : GetMyIpByTarget
see also : Network Information [W/L/M]
Service Data [W/L/M]
%HostID% : FQDN of the client in opsi service context, otherwise the computer name
%FQDN% : FQDN in network context
%opsiserviceURL%
%opsiServer%
%opsiDepotId% //since 4.11.4
%opsiserviceUser% FQDN used for the connection to the opsi-config-server
%opsiserviceClientId% : command line option /clientid
%opsiservicePassword%
%installingProdName%: productid //since 4.10.8
%installingProdVersion%: product version //since 4.10.8
%installingProduct% : productid (deprecated)
see also : Data for and from opsi service [W/L/M]
Functions to handle constants [W/L/M]
replaceOpsiConstants(<string list> ) : stringlist //since 4.12.3.6 [W/L/M]
see also : replaceOpsiConstants_list
replaceOpsiConstants(<string> ) : string //since 4.12.3.6 [W/L/M]
see also : replaceOpsiConstants_string
In Primary Sections
Kinds of Primary Sections [W/L/M]:
[Initial]
[sub<identifier> ]
sub <file name>
[ProfileActions] [W]
opsi-script control [W/L/M]:
encoding=<encoding> // (default is system encoding) since 4.11.4.2
see also : encoding
LogLevel (deprecated)
see also : Specification of Logging Level [W/L/M]
SetLogLevel = <number> or SetLogLevel = <string> // (default=6)
see also : SetLogLevel
SetLogLevel = 7
SetLogLevel = "7"
ExitOnError = <boolean value> // (default=false)
see also : ExitOnError
ScriptErrorMessages = <boolean value> // (default=true)
see also : ScriptErrorMessages
see also : Central configuration via opsi Configs
FatalOnSyntaxError = <boolean value> // (default=true) since 4.11.3.2
see also : FatalOnSyntaxError
FatalOnRuntimeError = <boolean value> // (default=false) since 4.11.3.2
see also : FatalOnRuntimeError
AutoActivityDisplay = <boolean value> // (default=false); if true shows a marquee (endless) progressbar while winbatch/ShellScript sections are . //since 4.11.4.7
see also : AutoActivityDisplay
forceLogInAppendMode = <boolean value> // (default=false); if true, log will be send in append mode . //since 4.12.3.6
see also : forceLogInAppendMode
Message <string> or Message = <const string>
see also : Message
ShowMessageFile <string>
see also : ShowMessageFile
ShowBitMap [<file name>] [<sub title>]
see also : ShowBitMap
comment <string> or comment = <const string>
see also : comment
LogError <string> or LogError = <const string>
see also : LogError
LogWarning <string> or LogWarning = <const string>
see also : LogWarning
includelog <file name> <tail size> //since 4.11.2.1 [W/L/M]
see also : includelog
includelog <file name> <tail size> [<encoding>] //since 4.11.4.1 [W/L/M]
includelog "%Scriptpath%\test-files\10lines.txt" "5"
SetConfidential <secret string> //since 4.11.3.5 [W/L/M]
see also : SetConfidential
asConfidential( <secret string expression> ) : string //since 4.12.0.16 [W/L/M]
see also : asConfidential_str
asConfidential( <secret stringlist expression> ) : stringlist //since 4.12.4.15 [W/L/M]
see also : asConfidential_list
Pause <string> or Pause = <const string>
see also : Pause
Stop <string> or stop = <const string>
see also : Stop
include_insert <file name> // since 4.11.3
see also : include_insert
include_append <file name> // since 4.11.3
see also : include_append
NormalizeWinst // (set normal window state) since 4.11.3
see also : NormalizeWinst
IconizeWinst // (set minimized window state)
see also : IconizeWinst
MaximizeWinst // (set maximized window state) // since 4.11.5.1
see also : MaximizeWinst
RestoreWinst // (restore last window state)
see also : RestoreWinst
SetSkinDirectory <path to skin.ini> // since 4.11.3.5
see also : SetSkinDirectory
runningInWanMode : boolean //since 4.12.4.17 [W/L/M]
see also : runningInWanMode
reloadProductList //since 4.12.6.1 [W/L/M]
see also : reloadProductList
Variables [W/L/M]:
Strings
DefVar <variable name> // since 4.12.4.32 also possible:
DefVar <variable name> [= <inital value>]
Set <variable name> = <value>
see also : String (or Text) Variables [W/L/M]
Stringlists
DefstringList <variable name>
; since 4.12.4.32 also possible:
DefstringList <variable name> [= <inital value>]
see also : Stringlist Variables [W/L/M]
Functions
String functions
Important
GetOS // 'Linux' or 'Windows_NT' [W/L/M]
see also : GetOS
getLinuxDistroType // 'debian' or 'redhat' or 'suse' (see getLinuxVersionMap) [L]
see also : getLinuxDistroType
GetMsVersionInfo //Windows Version Information [W]
see also : GetMsVersionInfo
GetMsVersionName //Windows Version Information [W]
see also : GetMsVersionName
GetSystemType //OS Architecture ("64 Bit System" or "x86 System") [W/L/M]
see also : GetSystemType
getOSArchitecture // OS Architecture (x86_32 / x86_64/ arm_64) //since 4.12.4.17 [W/L/M]
see also : getOSArchitecture
getRegistryValue(<keystr>, <varstr> ) : string //since 4.12.0.16 [W]
<access str> = one of 32bit, 64bit, sysnative ; default sysnative
see also : getRegistryValue
GetRegistrystringvalue ("[key] var") : string [W]
see also : GetRegistrystringvalue
GetRegistryStringValue32 ("[key] var") : string //since 4.10.8 [W]
see also : GetRegistryStringValue32
GetRegistryStringValue64 ("[key] var") : string //since 4.10.8 [W]
see also : GetRegistryStringValue64
GetRegistryStringValueSysNative ("[key] var") : string //since 4.10.8 [W]
see also : GetRegistryStringValueSysNative
GetValueFromInifile (<file path>, <section>, <key>, <default value>[, <encoding>]) : string [W/L/M]
see also : GetValueFromInifile
GetProductProperty (<PropertyName>, <DefaultValue> ) [W/L/M]
see also : GetProductProperty
GetConfidentialProductProperty (<PropertyName>, <DefaultValue> ) //since 4.11.5.2 [W/L/M]
see also : GetConfidentialProductProperty
trim(<string> ) [W/L/M]
see also : trim
lower(<string> ) [W/L/M]
see also : lower
upper(<string> ) [W/L/M]
see also : upper
unquote(<string>,<quote-string> ) //since 4.11.2.1 [W/L/M]
see also : unquote
unquote2(<string>,<quote-string> ) //since 4.11.5.2 [W/L/M]
see also : unquote2
stringReplace(<string>, <oldPattern>, <newPattern> ) //since 4.11.3 [W/L/M]
see also : stringReplace
strLength(<string> ) //since 4.11.3 [W/L/M]
see also : strLength
strPos(<string>, <sub string> ) //since 4.11.3 [W/L/M]
see also : strPos
strPart(<string>, <start pos>, <number of chars> ) //since 4.11.3 [W/L/M]
see also : strPart
getValue(<key string>, <hash string list> ) [W/L/M]
see also : getValue
getValueBySeparator(<key string>,<separator string>,<hash string list> ) //since 4.11.2.1 [W/L/M]
see also : getValueBySeparator
setValueByKey(<key>, <value>, <targetlist> ) [W/L/M]
see also : prim-section.adoc#setValueByKey
getValueFromFile(<key string>, <file name> ) //since 4.11.4.4 [W/L/M]
see also : getValueFromFile
getValueFromFileBySeparator(<key string>,<separator string>,<file name> ) //since 4.11.4.4 [W/L/M]
see also : getValueFromFileBySeparator
getLastExitCode : string (exitcode) [W/L/M]
see also : getLastExitCode
Special: License Management
DemandLicenseKey( poolId [, productId [,windowsSoftwareId]] )
set $mykey$ = DemandLicenseKey ("", "office2007")
see also : DemandLicenseKey
FreeLicense ( poolId [, productId [,windowsSoftwareId]] )
set $result$ = FreeLicense("", "office2007")
see also : FreeLicense
Special: Usercontext / loginscripts [W]:
GetUserSID(<Windows Username> )
see also : GetUserSID
GetLoggedInUser //since 4.11.1.2
see also : GetLoggedInUser
GetUsercontext //since 4.11.1.2
GetScriptMode possible values 'Machine','Login' //since 4.11.2.1
see also : GetUsercontext
saveVersionToProfile - save productversion-packageversion to local profile //since 4.11.2.1
see also : saveVersionToProfile
readVersionFromProfile : string - read productversion-packageversion from local profile //since 4.11.2.1
see also : readVersionFromProfile
scriptWasExecutedBefore : boolean - is true if saved and running productversion-packageversion are identical //since 4.11.2.1
see also : scriptWasExecutedBefore
Other
GetHostsName (<hostaddress> ) [W/L/M]
see also : GetHostsName
GetHostsAddr (<hostname> ) [W/L/M]
see also : GetHostsAddr
ExtractFilePath (<path> ) [W/L/M]
see also : ExtractFilePath
calculate(<arithmetic string expression> ) // since 4.11.3.5 : knows: +-*/() [W/L/M]
see also : calculate
DecStrToHexStr ( <decstring>, <hexlength> ) [W/L/M]
see also : DecStrToHexStr
HexStrToDecStr (<hexstring> ) [W/L/M]
see also : HexStrToDecStr
base64EncodeStr(<string> ) [W/L/M]
see also : base64EncodeStr
base64DecodeStr(<string> ) [W/L/M]
see also : base64DecodeStr
convert2Jsonstr(<string> ) //since 4.10.8.3
RandomStr [W/L/M]
see also : RandomStr
RandomStrWithParameters [W/L/M]
see also : RandomStrWithParameters
RandomIntStr(<number str> ) : string [W/L/M]
see also : RandomIntStr
CompareDotSeparatedStrings(<string1>, <string2> ) : string [W/L/M]
see also : CompareDotSeparatedStrings_str
CompareDotSeparatedNumbers(<string1>, <string2> ) : string [W/L/M]
see also : CompareDotSeparatedNumbers_str
EnvVar (<environment variable> ) [W/L/M]
see also : EnvVar
ParamStr [W/L/M]
see also : ParamStr
getDiffTimeSec (Time in seconds since last marktime) //since 4.11.3 [W/L/M]
see also : getDiffTimeSec
SidToName(<well known sid> ) //since 4.11.3: gives localized name of the sid [W]
see also : SidToName
GetMyIpByTarget(<target ip addr> ) : string //since 4.11.3.2 /4.11.6 [W/L/M]
GetIpByName(<ip addr / ip name> ) //since 4.11.3.2 [W/L/M]
see also : GetIpByName
reencodestr(<str>, <from>, <to> ) //since 4.11.4.2 [W/L/M]
see also : reencodestr
strLoadTextFile ( <filename> ) //since 4.11.4.6 [W/L/M]
see also : strLoadTextFile
strLoadTextFileWithEncoding ( <filename> , <encoding> ) //since 4.11.4.6 [W/L/M]
see also : strLoadTextFileWithEncoding
GetShortWinPathName(<longpath string>) //since 4.11.5.2 [W]
see also : GetShortWinPathName
stringinput(< message str>,< boolstr confidential> ) : string //since 4.12.1.2 [W/L/M]
see also : stringinput
which(<command in path> ) : string (command with path) //since 4.12.3.6 [W/L/M]
see also : which
ReadTOMLFile(<TOMLfilePath: String> ) : String //since 4.12.5.0 [W/L/M]
see also : ReadTOMLFile
GetTOMLAsString(<TOMLcontents: String> ) : String //since 4.12.5.0 [W/L/M]
see also : GetTOMLAsString
GetTOMLTableAsString(<TOMLcontents: String> , <table name : String> ) : String //since 4.12.5.0 [W/L/M]
see also : GetTOMLTableAsString
GetValueFromTOML(<TOMLcontents: String> , <keyPath: String> , <defaultValue: String> ) : String //since 4.12.5.0 [W/L/M]
see also : GetValueFromTOML
ModifyTOML(<TOMLcontents: String> , <command: String> , <keyPath: String> , <value: String> ) : String //since 4.12.5.0 [W/L/M]
see also : ModifyTOML
DeleteTableFromTOML(<TOMLcontents: String> , <tablePath: String> ) : String //since 4.12.5 [W/L/M]
see also : DeleteTableFromTOML
ConvertTOMLtoJSON(<TOMLcontents: String> ) : String //since 4.12.5.0 [W/L/M]
see also : ConvertTOMLtoJSON
Deprecated
GetNtVersion Deprecated - please use GetMsVersionInfo [W]
IniVar (<key> ) : (deprecated; use GetProductProperty) [W]
SubstringBefore (<string1>, <string2> ) (deprecated; use splitString / takestring) [W/L/M]
see also : splitString
String list functions
Important
splitString (<string1>, <string2> ) [W/L/M]
set $list1$ = splitString ("\\server\share\dir","\")
splitStringOnWhiteSpace (<string> ) [W/L/M]
see also : splitStringOnWhiteSpace
loadTextFile (<file name> ) [W/L/M]
see also : loadTextFile
loadUnicodeTextFile (<file name> ) [W]
see also : loadUnicodeTextFile
loadTextFileWithEncoding( <file name> , <encoding> ) //since 4.11.5 [W/L/M]
see also : loadTextFileWithEncoding
composeString (<string list>, <Link> ) [W/L/M]
see also : composeString
takeString (<index>, <list> ) [W/L/M]
see also : takeString
setStringInListAtIndex(<newstring>,<list>,<indexstr> ) : stringlist //since 4.11.6 [W/L/M]
see also : setStringInListAtIndex
takeFirstStringContaining(<list>,<search string> ) [W/L/M]
see also : takeFirstStringContaining
getOutStreamFromSection (<dos section name> ) [W/L/M]
set $list$= getOutStreamFromSection ('ShellScript_try')
see also : getOutStreamFromSection
shellCall (<command string> ) : stringlist (output) //since 4.11.4.2 [W/L/M]
set $list$= shellCall('net start')
see also : shellCall_list
getReturnListFromSection (<xml section name> ) [W/L/M]
see also : getReturnListFromSection
getListContaining(<list>,<search string> ) [W/L/M]
see also : getListContaining
getListContainingList(<list1>,<list2> ) //since 4.11.3.7 [W/L/M]
see also : getListContainingList
count (<list> ) [W/L/M]
see also : count
emptylist (<list> ) //since 4.11.3.7 [W/L/M]
see also : emptylist
for %<identifier> % in <list> do <one statement | sub section> [W/L/M]
for %s% in $list1$ do sub_test_string
see also : forInDo
GetProcessList //since 4.11.1.2; gives list of exename;pid;dom/user [W/L/M]
see also : GetProcessList
getProductPropertyList(<propname>,<default value> ) //since 4.11.3 [W/L/M]
see also : getProductPropertyList
getRegistryKeyList32(<regkey> ) //since 4.11.3 [W]
see also : getRegistryKeyList32
getRegistryKeyList64(<regkey> ) //since 4.11.3 [W]
see also : getRegistryKeyList64
getRegistryKeyListSysnative(<regkey> ) //since 4.11.3 [W]
see also : getRegistryKeyListSysnative
getRegistryKeyList(<regkey>, <access str> ) //since 4.12.5.0 [W]
getRegistryVarList32(<regkey> ) //since 4.11.3 [W]
see also : getRegistryVarList32
getRegistryVarList64(<regkey> ) //since 4.11.3 [W]
see also : getRegistryVarList64
getRegistryVarListSysnative(<regkey> ) //since 4.11.3 [W]
see also : getRegistryVarListSysnative
getRegistryVarList(<regkey>, <access str> ) //since 4.12.5.0 [W]
getProfilesDirList //since 4.11.3.2 [W/L/M]
see also : getProfilesDirList
listFiles (<Path>, <Searchmask> , <SearchSubDirectories>[, <Redirection>]) : stringlist //since 4.12.3 [W/L/M]
Set $Filelist$ = listFiles("C:\windows\system32","*.ico;*.dll","False","64bit")
see also : listFiles
Infomaps
GetLocaleInfoMap [W]
see also : GetLocaleInfoMap
GetMSVersionMap [W]
see also : GetMSVersionMap
getLinuxVersionMap //since 4.11.4 [L]
keys are (example):
Distributor ID=Ubuntu
Description=Ubuntu 12.04.2 LTS
Release=12.04
Codename=precise
kernel name=Linux
node name=detlefvm05
kernel release=3.2.0-40-generic-pae
kernel version=#64-Ubuntu SMP Mon Mar 25 21:44:41 UTC 2013
machine=i686
processor=athlon
hardware platform=i386
operating system=GNU/Linux
see also : getLinuxVersionMap
getFileInfoMap( <file name> ) [W]
see also : getFileInfoMap
getProductMap // since 4.11.2.4 [W/L/M]
keys are: id, name, description, advice, productversion, packageversion, priority, installationstate, lastactionrequest, lastactionresult, installedversion, installedpackage, installedmodificationtime,actionrequest
see also : getProductMap
getRegistryVarMap32(<regkey> ) //since 4.11.3 [W]
see also : getRegistryVarMap32
getRegistryVarMap64(<regkey> ) //since 4.11.3 [W]
see also : getRegistryVarMap64
getRegistryVarMapSysnative(<regkey> ) //since 4.11.3 [W]
see also : getRegistryVarMapSysnative
getRegistryVarMap(<regkey>, <access str> ) //since 4.12.5.0 [W]
getHWBiosInfoMap //since 4.11.4 [W/L/M]
see also : getHWBiosInfoMap
editmap(<strlist> ) : stringlist //since 4.12.1.2 [W/L/M]
see also : editmap
Other
createStringList (<string0>, <string1> ,… ) [W/L/M]
set $list1$ = createStringList ('a','b')
see also : createStringList
reverse (<list> ) [W/L/M]
see also : reverse
getSectionNames(<ini-file> ) [W/L/M]
see also : getSectionNames
retrieveSection (<section name> ) [W/L/M]
see also : retrieveSection
getSubList (<start index> : <end index>, <list> ) [W/L/M]
see also : getSubList
getSubListByMatch (<search string>, <target list> ) :stringlist //since 4.12.0.14 [W/L/M]
see also : getSubListByMatch_sl
getSubListByMatch (<search list>, <target list> ) :stringlist //since 4.12.0.14 [W/L/M]
see also : getSubListByMatch_ll
getSubListByContaining ( <search string>, <target list> ) :stringlist //since 4.12.0.14 [W/L/M]
see also : getSubListByContaining_sl
getSubListByContaining (<search list>, <target list> ) :stringlist //since 4.12.0.14 [W/L/M]
see also : getSubListByContaining_ll
getSubListByKey (<search string>, <target list> ) :stringlist //since 4.12.0.14 [W/L/M]
see also : getSubListByKey_sl
getSubListByKey (<search list>, <target list> ) :stringlist //since 4.12.0.14 [W/L/M]
see also : getSubListByKey_ll
getKeyList (<list> ) :stringlist //since 4.12.0.14 [W/L/M]
see also : getKeyList
addtolist(<list>,<string> ) //since 4.10.8 [W/L/M]
see also : addtolist
addListToList(<dest list>,<src list> ) //since 4.10.8 [W/L/M]
see also : addListToList
reencodestrlist(<list>, <from>, <to> ) //since 4.11.4.2 [W/L/M]
see also : reencodestrlist
removeFromListByContaining(<search string> , <target list> ) : stringlist //since 4.11.5.1 [W/L/M]
see also : removeFromListByContaining_str
removeFromListByContaining(<search list> , <target list> ) : stringlist //since 4.11.5.1 [W/L/M]
see also : removeFromListByContaining_list
removeFromListByMatch(<searchstring>,<target list> ) : stringlist //since 4.11.6 [W/L/M]
see also : removeFromListByMatch
LoadTOMLFile(<TOMLfilePath: String> ) : StringList //since 4.12.5 [W/L/M]
see also : LoadTOMLFile
GetTOMLAsStringList(<TOMLcontents: String> ) : StringList //since 4.12.5 [W/L/M]
see also : GetTOMLAsStringList
GetTOMLKeys(<TOMLcontents: String> ) : StringList //since 4.12.5 [W/L/M]
see also : GetTOMLKeys
GetTOMLTableNames(<TOMLcontents: String> ) : StringList //since 4.12.5 [W/L/M]
see also : GetTOMLTableNames
GetTOMLTable(<TOMLcontents: String> , <table name : String> ) : StringList //since 4.12.5 [W/L/M]
Boolean operators and functions
see also : Boolean Expressions
<string1> = <string2> [W/L/M]
<bool1> AND <bool2> [W/L/M]
<bool1> OR <bool2> [W/L/M]
NOT(<bool3>) [W/L/M]
FileExists (<file name> ) [W/L/M]
see also : FileExists
FileExists32 (<file name> ) [W]
FileExists64 (<file name> ) [W]
FileExistsSysNative (<file name> ) [W]
DirectoryExists (<folder path> ) //since 4.12.1 [W/L/M]
'sysnative' is the default for <access str>. Otherwise, it can be '32bit', '64bit' or 'sysnative'
see also : DirectoryExists
FileOrFolderExists (<file or folder path> ) [W/L/M]
see also : FileOrFolderExists
fileIsSymlink (<file name> ) // since 4.12.4.21 [W/L/M]
see also : fileIsSymlink
LineExistsIn (<string>, <file name> ) [W/L/M]
see also : LineExistsIn
LineBeginning_ExistsIn (<string>, <file name> ) [W/L/M]
see also : LineBeginning_ExistsIn
LineContaining_ExistsIn( <string>, <file name> ) //since 4.11.4.10: true: if a in <file name> contains <string> [W/L/M]
see also : LineContaining_ExistsIn
XMLAddNamespace(<XMLfilename>, <XMLelementname>, <XMLnamespace> ) [W]
see also : XMLAddNamespace
XMLRemoveNamespace(<XMLfilename>, <XMLelementname>, <XMLnamespace> ) [W]
see also : XMLRemoveNamespace
HasMinimumSpace (<drive letter>, <capacity> ) [W]
see also : HasMinimumSpace
Example:
if not (HasMinimumSpace ("%SYSTEMDRIVE%", "500 MB"))
LogError "Required free space of 500 MB not available on %SYSTEMDRIVE%"
isFatalError
opsiLicenseManagementEnabled [W/L/M]
see also : opsiLicenseManagementEnabled
runningAsAdmin //since 4.11.1.1 [W/L/M]
see also : runningAsAdmin
isLoginScript //since 4.11.2.1 [W]
see also : isLoginScript
contains(<str>, <substr> ) //since 4.11.3: true if <substr> in <str> [W/L/M]
see also : contains
isNumber(<str> ) //since 4.11.3: true if <str> represents an integer [W/L/M]
see also : isNumber
runningOnUefi //since 4.11.4.3: true: if the running OS was booted in UEFI mode [W]
see also : runningOnUefi
runningInPE //since 4.12.0.13: true: if the running OS is a Windows PE [W/L/M]
see also : runningInPE
runningInWAnMode //since 4.12.4.16: true: if opsiserver = localhost [W/L/M]
see also : runningInWAnMode
isDriveReady(<drive letter> ) //since 4.11.4.4: true: if the drive can be accessed [W]
see also : isDriveReady
runningWithGui //since 4.12.3.6: true: if the running OS has a GUI (at Win+Mac always true)[M/L/W]
see also : runningWithGui
saveTextFile(<list>, < filename> ) //since 4.11.4.4: true: if list is succesfully written to file [W/L/M]
see also : saveTextFile
saveTextFileWithEncoding(<list>, < filename>, <encoding> ) //since 4.11.6.4: true: if list is succesfully written to file [W/L/M]
see also : saveTextFileWithEncoding
saveUnicodeTextFile(<list>, < filename>, <encoding> ) //since 4.12.4.13: true: if list is succesfully written to unicode file [W/L/M]
see also : saveUnicodeTextFile
CompareDotSeparatedNumbers(<str1>,<relation str>,<str2> ) //since 4.11.5.2: [W/L/M]
see also : CompareDotSeparatedNumbers_bool
CompareDotSeparatedStrings(<str1>,<relation str>,<str2> ) //since 4.11.5.2: [W/L/M]
see also : CompareDotSeparatedStrings_bool
RegKeyExists(<regkey>[,<access str>]) //since 4.12.0.16 [W]
see also : RegKeyExists
RegVarExists(<regkey>, <var str>[,<access str>]) //since 4.12.0.16 [W]
see also : RegVarExists
isPingReachable(<host> ) //since 4.12.3.6 [W/L/M]
see also : isPingReachable
isValidFQDN(<domain name> ) //since 4.12.4.4 [W/L/M]
see also : isValidFQDN
fileHasBom (<file name> ) //since 4.12.4.17 [W/L/M]
see also : fileHasBom
SaveToTOMLFile(<TOMLcontents: String> , <TOML file Path: String> ) //since 4.12.5 [W/L/M]
see also : SaveToTOMLFile
ConvertTOMLfileToJSONfile(<TOMLfilePath: String> , <JSONfilePath: String> ) //since 4.12.5 [W/L/M]
see also : ConvertTOMLfileToJSONfile
Misc functions
Killtask <process name> [W/L/M]
see also : Killtask
requiredOpsiscriptVersion <relation operator> <version> //since 4.12.3.6 [W/L/M]
requiredOpsiscriptVersion >= "4.12.3.6"
see also : requiredOpsiscriptVersion
requiredWinstVersion <relation operator> <version> [W/L/M]
outdatet - use requiredOpsiscriptVersion
UpdateEnvironment //since 4.11.5 [W]:
Subsequent calls of winbatch with the parameter /RunElevated will see the changed Environment (NT6 only).
see also : UpdateEnvironment
Flow control
'if - elseif - else - endif' [W/L/M] see also : Syntax und Bedeutung der primären Sektionen eines opsi-script Skripts [W/L/M]]
Syntax:
if <condition>
;statement(s)
[elseif <condition>
;statement(s)]
[else
;statement(s)]
elseif //since 4.12.4.37
Example:
Set $NTVer$ = GetMsVersionInfo
if ( $NTVer$ >= "6" )
sub_install_win7
else
if ( $NTVer$ = "5.1" )
sub_install_winXP
else
'for - to - do' Statement //since 4.11.5 [W/L/M] see also : ForToDo
for %<temporary string variable>% = <start string> to <end string> do <one statement>
Example:
for %s% = "1" to "5" do sub_iteration_test
'Switch / Case' Statement //since 4.11.5 [W/L/M]
ifdef::manual[see also : SwitchCase]
Can not be nested.
see also : IfElseEndif
Syntax:
Switch <string expression>
Case <string const>
<statement(s)>
EndCase
[DefaultCase
<statement(s)>
EndCase]
EndSwitch
Example:
set $ConstTest$ = "5"
Switch $ConstTest$
Case "1"
set $CompValue$ = "1"
EndCase
Case "2"
set $CompValue$ = "2"
EndCase
DefaultCase
set $CompValue$ = "notexisting"
EndCase
EndSwitch
isFatalError [W/L/M]
see also : isFatalError
isFatalError <string> //since 4.11.3.2 [W/L/M]
isSuccess //since 4.11.3.7 [W/L/M]
see also : isSuccess
isSuspended //since 4.11.4.1 [W/L/M]
see also : isSuspended
noUpdateScript //since 4.11.3.7 [W/L/M]
see also : noUpdateScript
ExitWindows /Reboot [W/L/M]
see also : Reboot
ExitWindows /ImmediateReboot [W/L/M]
see also : ImmediateReboot
ExitWindows /ImmediateLogout [W]
see also : ImmediateLogout
ExitWindows /ShutdownWanted [W]
see also : ShutdownWanted
ExitWindows /RebootWanted (deprecated, acts like /Reboot) [W]
see also : Reboot
sleepSeconds <Integer> or <string> : noresult [W/L/M]
see also : sleepSeconds
ChangeDirectory <directory> //since 4.11.2.6 [W/L/M]
see also : ChangeDirectory
Secondary Sections
Winbatch [W/L/M]
see also : WinBatch-Sections [W/L/M]
Function: execute programs via operating system API
[WinBatch<identifier> ]
Modifier:
/LetThemGo
/WaitForProcessEnding "<program.exe>"
/TimeOutSeconds <seconds>
/WaitForWindowAppearing <window title> ('does not work with 64 Bit programs') [W]
/WaitForWindowVanish <window title> ('does not work with 64 Bit programs') [W]
/RunElevated // since 4.11.3: only at >= NT6 ; no network access [W]
/RunAsLoggedOnUser // since 4.11.3.5 ; works only inside 'userLoginScripts' [W]
/32Bit //since 4.11.3.5 [W]
/64Bit //since 4.11.3.5 [W]
/SysNative //since 4.11.3.5 [W]
ShellScript (deprecated: DosBatch, DosInAnIcon, ShellBatch, ShellInAnIcon) //since 4.12.10.0 [W/L/M]
see also : ShellScript section
see also : ShellScript Sections
Function: Execute section via cmd.exe [W] or bash [L/M]
[ShellScript<identifier> ] <optional parameters> <winst <modifier>>
Modifier: //since 4.11.1.1
/32Bit [W]
/64Bit [W]
/SysNative [W]
/showoutput [W/L/M] // since 4.11.4.7
/WaitForProcessEnding "<program.exe>" // since 4.12.4 [W/L/M]
/TimeOutSeconds <seconds> // since 4.12.4 [W/L/M]
/LetThemGo //since 4.12.10.0
/RunElevated // since 4.12.4: only at >= NT6 ; no network access [W]
/RunAsLoggedOnUser // since 4.12.4.31 ; works only inside 'userLoginScripts' [W]
The modifiers has to be seperated by 'winst' from the parameters.
ShellScript_do_64bit_stuff winst /64Bit
ExecWith [W/L/M]
see also : ExecWith Sections
Function: Execute section via any interpreter
[ExecWith<identifier> ] <path to interpreter>
Modifier:
/LetThemGo
/EscapeStrings
The modifiers has to be seperated by 'winst' from the parameters. The following example call the 64Bit version of the powershell.exe.
ExecWith_do_64bit_stuff "%System%\WindowsPowerShell\v1.0\powershell.exe" winst /64Bit
Commands: see manual
Files [W/L/M]
see also : Files
Function: File Operations
[Files<identifier> ]
Modifier [W]:
/AllNTUserProfiles
/AllNTUserSendTo [W]
/32Bit //since 4.10.8 [W]
/64Bit //since 4.10.8 [W]
/SysNative //since 4.10.8 [W]
Commands:
checkTargetPath = <destination directory> [W/L/M]
copy [Options] <source file(s)> <destination directory> [W/L/M]
some options:
-s recursive [W/L/M]
-e empty Subdirectories
-V version control against targetdir [W]
-v version control against targetdir, %systemroot% and %system% (do not use it) [W]
-c continue without reboot even if it is needed [W]
-d date check [W]
-u update [W]
-x extract [W]
-w weak (do not overwrite protected files) [W]
-n no overwrite [W]
-r copy read only attribute [W]
-h follow symlinks [L] //since 4.11.6.14
delete [Options] <path[/mask]] // [W/L/M]
options:
-s recursive
-f force
r -del on reboot
c continue with out reboot
d [n] date
Example (do not forget the trailing Backslash):
delete -sf c:\delete_this_dir\
del [Options] <path[/mask]] //since 4.11.2.1 [W/L/M]
Works like delete but on
del -s -f c:\not-exists
if c:\not-exists not exists it do not search complete c:\ for not-exits
Example (you may forget the trailing Backslash):
del -sf c:\delete_this_dir
chmod <mode> <path> //since 4.11.4.1 [L]
hardlink <existing file> <new file> // since 4.11.5 [W/L/M]
symlink <existing file> <new file> // since 4.11.5 [W/L/M]
At Windows symlink is only available at NT6 and up.
rename <old filename> <new filename> // since 4.11.5 [W/L/M]
move <old filename> <new filename> // since 4.11.5 [W/L/M]
zipfile <source dir> <zip file> // since 4.12.1 [W/L/M]
unzipfile <zip file> <target dir> [<encoding>] // since 4.12.1 [W/L/M]
Registry [W]
see also : Registry
Function: edit Registry
Standard method call:
[Registry<identifier> ]
works with the specified section.
Alternative method call:
Registry loadUnicodeTextFile(<.reg file> ) /regedit
import the specified <.reg file>.
Alternative method call (deprecated):
Registry loadUnicodeTextFile(<.addreg file> ) /addreg
import the specified <.addreg file>.
Modifier:
/AllNTUserDats
Commands:
OpenKey <Key>
openkey [HKLM\Software\opsi.org]
Set <varname> = <registry type>:<value>
Add <varname> = <registry type>:<value>
Examples for registry types:
set "var1" = "my string"
set "var2" = REG_SZ:"my string"
set "var3" = REG_EXPAND_SZ:"%ProgramFiles%"
set "var4" = REG_DWORD:123 ; Decimal
set "var5" = REG_DWORD:0x7b ; Hexadecimal
; REG_QWORD is supported since 4.12.6
set "var6" = REG_QWORD:59049772908 ; Decimal
set "var7" = REG_QWORD:0xDBFA4076C ; Hexadecimal
set "var8" = REG_BINARY:00 01 02 0F 10
set "var9" = REG_MULTI_SZ:"A|BC|de"
Supp <varname> <list char> <supplement>
supp "Path" ; "C:\utils; %JAVABIN%"
GetMultiSZFromFile <varname> <file name>
SaveValueToFile <varname> <file name>
DeleteVar <varname>
DeleteKey <registry key> (does since 4.11.2.1 also work with /AllNTUserDats)
Patches [W/L/M]
see also : Patches
Function: edit Ini-files
[Patches<identifier> ] <file name>
Modifier:
/AllNTUserProfiles //since 4.11.3 [W]
Commands:
add [<section name> ] <variable1> = <value1>
set [<section name> ]<variable1> = <value1>
addnew [<section name> ]<variable1> = <value1>
change [<section name> ]<variable1> = <value1>
del [<section name> ] <variable1> = <value1>
delsec [<section name> ]
replace <variable1> =<value1> <variable2> =<value2>
PatchTextFile [W/L/M]
see also : PatchTextFile
Function: edit text files
[PatchTextFile<identifier> ] <file name>
Modifier:
/AllNTUserProfiles //since 4.11.3.4 [W]
/encoding <encoding> //since 4.12.4.17 [W/L/M]
Commands:
Set_Mozilla_Pref (<preference type>, <preference key>, <preference value> )
'preference type' takes any value.
Some examples for preference types: pref, user_pref, lock_pref or lockPref.
AddStringListElement_To_Mozilla_Pref (<preference type>, <preference key>, <add value> )
Set_Netscape_User_Pref (<key>, <value> ) ('deprecated')
AddstringListElement_To_Netscape_User_Pref ('deprecated')
FindLine <search string>
FindLine_StartingWith <search string>
FindLine_Containing <search string>
GoToTop
AdvanceLine [<number of lines>]
GoToBottom
DeleteTheLine
AddLine_ <line> or Add_Line_ <line>
InsertLine <line> or Insert_Line_ <line>
AppendLine <line> or Append_Line <line>
Append_File <file name>
Subtract_File <file name>
SaveToFile <file name>
Sorted
setKeyValueSeparator <separator char> //since 4.11.4.4 [W/L/M]
setValueByKey <keystr> <valuestr> //since 4.11.4.4 [W/L/M]
searchAndReplace <searchstr> <replacestr> //since 4.11.4.6 [W/L/M]
LinkFolder [W/L/M]
see also : LinkFolder
Function: Startmenue + Desktop Icons
[LinkFolder<identifier> ]
Commands:
set_basefolder <system folder>
set_subfolder <folder path> (at Linux set always "")
set_link name: <link name> target: <path and name of the program> parameters: [command line arguments] working_dir: [working directory] icon_file: [path and name of icon file, default=target] icon_index: [number of icon in icon file, default=0] [W] shortcut: [keyboard shortcut for calling the target] [W] link_categories: [list of categories] [L] end_link
delete_element <link name>
delete_subfolder <folder path> [W]
The predefined virtual system folders which can be used are at Windows:
desktop, sendto, startmenu, startup, programs, desktopdirectory,
common_startmenu, common_programs, common_startup, common_desktopdirectory
and at Linux:
common_programs,common_startup,desktop, startup
Predefined link_categories for Linux:
AudioVideo, Audio, Video, Development, Education, Game, Graphics, Network, Office, Settings, System, Utility
Examples
set_basefolder common_desktopdirectory
set_subfolder ""
set_link
target: "%ProgramFiles32Dir%\opsi.org\opsi-client-agent\opsi-winst\winst32.exe"
end_link
[LinkFolder_configed_lin]
set_subfolder ""
set_link
target: java
parameters: $parameter$
icon_file: "$InstallDir$/opsi.png"
link_categories: System;Utility;
end_link
The predefined virtual system folders:
are pointing to the folders of the user that the script is running.
If you use it in a userLoginScript with the opsi 'User Profile Management' extension these virtual folders point to the folder of the user that just had logged in.
'shortcut' defaults to empty. // since 4.11.6.7
shortcut may be a combination of ['shift','alt','ctrl'] (not case sensitiv) divided by ' ', '-','+' an a 'Key' or a 'Virtual Key Code'.
The 'Key' is a letter ('A' - 'Z') or a numeral ('0' - '9'). All other Keys must be given by there 'Virtual Key Code' identifier.
OpsiServiceCall [W/L/M]
see also : OpsiServiceCall
Function: opsi-Service access
[OpsiServiceCall<identifier> ]
PatchHosts [W/L/M]
see also : PatchHosts
Function: hosts-files bearbeiten
[PatchHosts<identifier> ]
Commands:
setaddr <hostname> <IPaddress>
setname <IPaddress> <hostname>
setalias <hostname> <alias>
setalias <IPadresse> <alias>
delalias <hostname> <alias>
delalias <IPaddress> <alias>
delhost <hostname>
delhost <ipadresse>
setComment <ident> <comment>
XML2 Sections [W/L/M]
see also : XML2 Sections
Function: edit XML files
since 4.12.1.0
[XML2<identifier> ]
Commands:
strictMode =(true/false) ; Default: false -
openNode<xml2 path>
Open the given path as actual node. If the path does not exist, it will be created. -
SetAttribute<attr name> <attr value>
At the actual node set <attr value> as value of <attr name>. If <attr name> does not exist, it will be created. -
AddAttribute<attr name> <attr value>
If the attribute <attr name> does not exist at the actual node, it will be created with <attr value> as value. If <attr name> already exists, nothing will be changed. -
DeleteAttribute<attr name>
If the attribute <attr name> exists at the actual node, it will be deleted. -
addNewNode<node name>
Create at the actual node a new sub node <node name> and make this new node to the actual node. -
setNodeText<string> -
DeleteNode<xml2 path> -
gotoParentNode
Make the parent node to the actual node. -
rootNodeOnCreate= <node name> // since 4.12.4.27
If the file does not exist, it will be created with <node name> as root node name. -
setNodePair<keyNodeName> <keyNodeTextContent> <valueNodeName> <valueNodeTextContent> // since 4.12.4.28
Creates a <dict> entry like it is used in the Apple info.plist files.
Some notes on the command parameters:
<xml2 path>
strictMode =false:
A line of xml node names without any attributes seprated by//.
Example:node_level-1_number-1 // node_level-2_B color="green" -
<xml2 path>
strictMode =true:
A line of xml node names with all existing attributes seprated by//.
Example:node_level-1_number-1 // node_level-2_B color="green" count="65"
see also : XML related functions (XML2) [W/L/M]:
see also : XML2 Functions
XMLPatch [W]
see also : XMLPatch
Deprecated: please use xml2 sections: XML2 Sections [W/L/M]
and xml2 functions: XML related functions (XML2) [W/L/M]:
[XMLPatch<identifier> ]
ExecPython [W/L/M]
see also : ExecPython
Function: Execute section via python interpreter
[ExecPython<identifier> ]
LdapSearch [WLM]
see also : LdapSearch
Function: read from LDAP
[LdapSearch<identifier> ]
By Topic
Compare related functions [W/L/M]
CompareDotSeparatedStrings(<str1>,<relation str>,<str2> ) : bool //since 4.11.5.2: [W/L/M]
CompareDotSeparatedNumbers(<str1>,<relation str>,<str2> ) : bool //since 4.11.5.2: [W/L/M]
boolToString(<boolean expression> ) : bool string (true/false) // since 4.12.0.0 [W/L/M]
see also : boolToString
stringToBool(<string expression: true/false> ) : boolean // since 4.12.0.0 [W/L/M]
see also : stringToBool
Crypt / Hash related functions [W/L/M]
DecStrToHexStr ( <decstring>, <hexlength> ) : string [W/L/M]
HexStrToDecStr (<hexstring> ) : string [W/L/M]
base64EncodeStr(<string> ) : string [W/L/M]
base64DecodeStr(<string> ) : string [W/L/M]
RandomStr : string [W/L/M]
encryptStringBlow(<keystring>,<datastring> ) : string [W/L/M]
see also : encryptStringBlow
decryptStringBlow(<keystring>,<datastring> ) : string [W/L/M]
see also : decryptStringBlow
md5sumFromFile(<path to file> ) : string [W/L/M]
see also : md5sumFromFile
hashFromFile(<FileName>, <Hashing Algorithm> ) : string [W/L/M] //since 4.12.5
see also : hashFromFile
isCertInstalledInSystem(<label> ) : boolstring [W/L/M] //since 4.12.4.37
see also : isCertInstalledInSystem
importCertToSystem(<filename> ) : noresult [W/L/M] //since 4.12.4.37
see also : importCertToSystem
removeCertFromSystem(<label> ) : noresult [W/L/M] //since 4.12.4.37
see also : removeCertFromSystem
listCertificatesFromSystem : stringlist [W/L/M] //since 4.12.4.37
see also : listCertificatesFromSystem
Defined Functions and Libraries [W/L/M]
since 4.12.0.0
Definition
DefFunc <func name>([calltype parameter ptype][,[calltype parameter ptype]]) : ftype <function body> endfunc
Where:
DefFuncis the keyword used to start defining a local function. -
'<func name>' is the freely choosen name of the function.
'calltype' is the call type of the parameter [
val|ref].val='Call by Value',ref='Call by Reference'. Default:val -
'parameter' is the freely selected name of the call parameter which is available as a local variable within the function under the aforementioned name.
'ptype' is the type of data of the parameter and either
stringorstringlist. -
'ftype' is the type of data of the function and either
string,stringlistorvoid.voiddeclares that no result is returned. -
'<function body>' is the body of the function which must conform to the opsi-script syntax.
endfuncis the keyword used to end defining a local function.
see also : localfunctions
importLib <string expr> ; import library // since 4.12.0.0
<string expr> : <file name>[.<file extension>][::<function name>]
If no '.<file extension>' is given .opsiscript is used as default.
If no '::<function name>' is given, all function from the given file will be imported.
<file name> is:
A complete path to an existing file. [W/L/M]
An existing file in
%ScriptPath%[W/L/M] -
A file in
%opsiScriptHelperPath%\lib[W]
Is equivalent to: '%ProgramFiles32Dir%\opsi.org\opsiScriptHelper\lib' -
An existing file in
%ScriptPath%/../lib[W/L/M] -
An existing file in
%WinstDir%\lib[W] or/usr/share/opsi-script/lib[L]
The tests for the location of the <file name> are done in the order above. 'opsi-script' uses the first file it finds that has a matching name.
see also : Import of libraries of functions
Encoding related functions [W/L/M]
see also : encoding
GetLocaleInfoMap : stringlist [W]
reencodestr(<str>, <from>, <to> ) : string //since 4.11.4.2 [W/L/M]
reencodestrlist(<list>, <from>, <to> ) : stringlist //since 4.11.4.2 [W/L/M]
fileHasBom (<file name> ) : boolean //since 4.12.4.17 [W/L/M]
loadUnicodeTextFile (<file name> ) : stringlist [W/L/M]
loadTextFileWithEncoding( <file name> , <encoding> ) : stringlist //since 4.11.5 [W/L/M]
strLoadTextFileWithEncoding ( <filename> , <encoding> ) : string //since 4.11.4.6 [W/L/M]
saveTextFileWithEncoding(<list>, < filename> , <encoding> ) : bool //since 4.11.6.4: true: if list is succesfully written to file [W/L/M]
includelog <file name> <tail size> [<encoding>] : noresult //since 4.11.4.1 [W/L/M]
see also : 'opsi-script' encoding
Error / Warning related functions [W/L/M]
see also : LogError
markErrorNumber
see also : markErrorNumber
errorsOccurredSinceMark <relation> <integer> : boolean
see also : errorsOccurredSinceMark
markErrorNumber
LogError "log error and thereby increase the error counter"
if errorsOccurredSinceMark > 0
isFatalError "There was an error ..."
shellCall (<command string> ) : string (exitcode) //since 4.11.6.1 [W/L/M]
see also : shellCall_str
processCall(<string> ) : string (exitcode) //since 4.11.6.1 [W/L/M]
see also : processCall
getLastServiceErrorClass : string
see also : getLastServiceErrorClass
getLastServiceErrorMessage : string
see also : getLastServiceErrorMessage
File related functions [W/L/M]
strLoadTextFile (<file name> ) : string [W/L/M]
loadTextFile (<file name> ) : stringlist [W/L/M]
loadUnicodeTextFile (<file name> ) : stringlist [W]
FileExists (<file name> ) : bool [W/L/M]
FileExists32 (<file name> ) : bool [W]
FileExists64 (<file name> ) : bool [W]
FileExistsSysNative (<file name> ) : bool [W]
DirectoryExists (<folder path> [,<access str>]) : boolean //since 4.12.1 [W/L/M]
FileOrFolderExists (<file or folder path> [,<access str>]) : boolean [W/L/M]
fileIsSymlink (<file name> ) : bool // since 4.12.4.21 [W/L/M]
resolveSymlink (<file name> ) : string // since 4.12.4.21 [W/L/M]
see also : resolveSymlink
listFiles (<Path>, <Searchmask> , <SearchSubDirectories>, <[Redirection]> ) : stringlist //since 4.12.3 [W/L/M]
forcePathDelims (<path string> ) : string // since 4.12.4.21 [W/L/M]
see also : forcePathDelims
LineExistsIn (<string>, <file name> ) : bool [W/L/M]
LineBeginning_ExistsIn (<string>, <file name> ) : bool [W/L/M]
LineContaining_ExistsIn( <string>, <file name> ) : bool //since 4.11.4.10 [W/L/M]
saveTextFile(<list>, < filename> ) : bool //since 4.11.4.4 [W/L/M]
saveTextFileWithEncoding(<list>, < filename> , <encoding> ) : bool //since 4.11.6.4 [W/L/M]
getFileInfoMap( <file name> ) : stringlist [W]
getFileInfoMap32( <file name> ) : stringlist //since 4.11.6.6 [W]
getFileInfoMap64( <file name> ) : stringlist //since 4.11.6.6 [W]
getFileInfoMapSysnative( <file name> ) : stringlist //since 4.11.6.6 [W]
ExtractFilePath (<path> ) : string [W/L/M]
ExtractFileExtension (<path> ) : string [W/L/M] //since 4.12.1
see also : ExtractFileExtension
ExtractFileName (<path> ) : string [W/L/M] //since 4.12.1
see also : ExtractFileName
see also: Files [W/L/M]
see also: PatchTextFile [W/L/M]
Ini file related functions [W/L/M]
GetValueFromInifile (<file path>, <section>, <key>, <default value>, OPTIONAL <encoding> ) : string [W/L/M]
getSectionNames(<ini-file> ) : stringlist [W/L/M]
GetSectionFromInifile(<ini-file> ) : stringlist [W/L/M]
see also : GetSectionFromInifile
getValue(<key string>, <hash string list> ) : string [W/L/M]
see also : getValue
getValueBySeparator(<key string>,<separator string>,<hash string list> ) : string //since 4.11.2.1 [W/L/M]
setValueByKey(<key>, <value>, <targetlist> ) : stringlist [W/L/M]
getValueFromFile(<key string>, <file name> ) : string //since 4.11.4.4 [W/L/M]
getValueFromFileBySeparator(<key string>,<separator string>,<file name> ) : string //since 4.11.4.4 [W/L/M]
see also: Patches [W/L/M]
Interaction [W/L/M]
see also : Pause
see also : Stop
setActionProgress <string> //since 4.11.3 [W/L/M]
see also : setActionProgress
see also : Message
editmap(< strlist> ) : stringlist //since 4.12.1.2 [W/L/M]
see also : editmap
License Management related functions [W/L/M]
DemandLicenseKey( poolId [, productId [,windowsSoftwareId]] ) : string
FreeLicense ( poolId [, productId [,windowsSoftwareId]]) : string
opsiLicenseManagementEnabled : bool
Linux specific functions [W/L/M]
GetOS : string // 'Linux' or 'Windows_NT' or 'macos' [W/L/M]
see also : GetOS
getLinuxDistroType : string // 'debian' or 'redhat' or 'suse' (see getLinuxVersionMap) [L]
getLinuxVersionMap : stringlist //since 4.11.4 [L]
chmod in Files sections [L/M]
see also : Commands
waitForPackageLock(<wait_seconds>,<abort_on_timeout> ) : bool // since 4.11.6.1 [L]
see also : waitForPackageLock
importlib "uib_lin_install" :
cleanupPackageSystem : void //since 4.13.4 [L]
see also : cleanupPackageSystem
installupdates : string //since 4.13.4 [L]
see also : installupdates
debinstall($packagelist$ : stringlist) : string //since 4.13.4 [L]
see also : debinstall
redinstall($packagelist$ : stringlist) : string //since 4.13.4 [L]
see also : redinstall
suseinstall($packagelist$ : stringlist) : string //since 4.13.4 [L]
see also : suseinstall
ucsinstall($packagelist$ : stringlist) : string //since 4.13.4 [L]
see also : ucsinstall
genericLinInstall($packagelist$ : stringlist) : string
see also : genericLinInstall
linuxInstallOneOf($packagelist$ : stringlist) : string
isOneInstalled($packagelist$ : stringlist) : string
see also : linuxInstallOneOf
linuxInstallOneFile($packagefile$ : string) : string
see also : linuxInstallOneFile
linuxRemoveOnePackage($packagename$ : string) : string
see also : linuxRemoveOnePackage
linuxRemoveOneOf($packagelist$ : stringlist) : string
see also : linuxRemoveOneOf
Logging related functions [W/L/M]
SetLogLevel = 7
SetLogLevel = "7"
see also : SetLogLevel see also : cli-params.adoc#opsi-script-configs_default_loglevel see also : cli-params.adoc#opsi-script-configs_force_min_loglevel
see also : Message
see also : comment
see also : LogError
see also : setConfidential
opsi-configs
opsi-script.global.debug_prog : boolean ; if false: only Warnings and Errors from program logging; default: false
opsi-script.global.debug_lib : boolean ; if false: only Warnings and Errors from library logging; default: false
opsi-script.global.default_loglevel : intstr ; set the default log level; default: '6'
opsi-script.global.force_min_loglevel : intstr ; set the minimal loglevel; default: '0'
opsi-script.global.ScriptErrorMessages : boolean ; overwrites the opsi-script internal default; default: false
opsi-script.global.AutoActivityDisplay : boolean ; overwrites the opsi-script internal default; default: true
opsi-script.global.SupressSystemEncodingWarning : boolean ; suppress some encoding warnings; default: false
see also : SupressSystemEncodingWarning
opsi-script.global.ReverseProductOrderByUninstall : boolean ; product list is reordered for uninstall; default: false
see also : ReverseProductOrderByUninstall
opsi-script.global.log_rotation_count : boolean ; number of opsi-script.log backups; default: 8
see also : log_rotation_count
opsi-script.global.writeProductLogFile : boolean ; logs for every single opsi product; default: false
see also : writeProductLogFile
macOS specific functions [W/L/M]
see also : GetOS
getMacosVersionInfo : string //macOS Version Information //since 4.12.1.0 [M]
see also : getMacosVersionInfo
getMacosVersionMap : stringlist //macOS Version map //since 4.12.1.0 [M]
see also : getMacosVersionMap
GetSystemType : string //OS Architecture ("64 Bit System" or "x86 System") [W/L/M]
importlib "uib_macosinstalllib" :
install_macos_app($myapp$ : string) : string [M]
see also : xref:libraries.adoc#install_macos_app>>
install_macos_pkg($mypkg$ : string) : string [M]
see also : xref:libraries.adoc#install_macos_pkg>>
install_macos_dmg($mydmg$ : string) : string [M]
see also : xref:libraries.adoc#install_macos_dmg>>
install_macos_zip($myzip$ : string) : string [M]
see also : xref:libraries.adoc#install_macos_zip>>
install_macos_generic($myfile$ : string) : string [M]
see also : install_macos_generic
Network related functions [W/L/M]
GetHostsName (<hostaddress> ) : string [W/L/M]
GetHostsAddr (<hostname> ) : string [W/L/M]
GetIpByName(<ip addr / ip name> ) : string //since 4.11.3.2 [W/L/M]
isValidIP4 (<ip4adr>) : boolean //since 4.12.1
see also : isValidIP4
isValidIP4Network (<ip4adr>, <netmask>) : boolean //since 4.12.1
see also : isValidIP4Network
isValidIP4Host (<ip4adr>, <netmask>) : boolean //since 4.12.1
see also : isValidIP4Host
getIP4NetworkByAdrAndMask (<ip4adr>, <netmask>) : string //since 4.12.1
see also : getIP4NetworkByAdrAndMask
getDefaultNetmaskByIP4adr (<ip4adr>) : string //since 4.12.1
see also : getDefaultNetmaskByIP4adr
parseUrl(<url string>) : stringlist //since 4.12.1
see also : parseUrl
createUrl(<urlcomponents list>) : string //since 4.12.1
see also : createUrl
isPingReachable(<host>) : boolean //since 4.12.3.6
isValidFQDN(<domain name>) : boolean //since 4.12.4.4 [W/L/M]
cidrToNetmask (<string>) : string //since 4.12.4.37
see also : prim-section.adoc#cidrToNetmask
netmaskToCidr (<string>) : string //since 4.12.4.37
see also : prim-section.adoc#netmaskToCidr
see also : prim-section.adoc#sCertInstalledInSystem
see also : prim-section.adoc#importCertToSystem
see also : prim-section.adoc#removeCertFromSystem
listCertificatesFromSystem(<label> ) : stringlist [W/L/M] //since 4.12.4.37
see also : prim-section.adoc#listCertificatesFromSystem
Number related functions [W/L/M]
isNumber(<str> ) : bool //since 4.11.3: true if <str> represents an integer [W/L/M]
see also : isNumber
calculate(<arithmetic string expression> ) : string (number) // since 4.11.3.5 [W/L/M]
knows: +-*/()
Operating System related functions [W/L/M]
see also : GetOS
GetMsVersionInfo : string //Windows Version Information [W]
GetMSVersionMap : stringlist [W]
getListFromWMI(<wmi namespace str>,<wmi class str>,<property list>,<condition str> ) : stringlist //since 4.12.1.0 [W]
see also : getListFromWMI
EnvVar (<environment variable> ) : string [W/L/M]
see also : EnvVar
getProfilesDirList : stringlist //since 4.11.3.2 [W/L/M]
see also : which
runningAsAdmin : bool //since 4.11.1.1 [W/L/M]
runningOnUefi : bool //since 4.11.4.3: true: if the running OS was booted in UEFI mode [W/L/M]
runningInPE : bool //since 4.12.0.13: true: if the running OS is a Windows PE [W]
isDriveReady(<drive letter> ) : bool //since 4.11.4.4: true: if the drive can be accessed [W]
runningWithGui : bool //since 4.12.3.6: true: if the running OS with GUI (at Win+Mac always true)[M/L/W]
opsiservicecall and json Related functions [W/L/M]
jsonIsValid(<jsonstr> ) : boolean //since 4.11.6: [W/L/M]
see also : jsonIsValid
jsonIsArray(<jsonstr> ) : boolean //since 4.11.6: [W/L/M]
see also : jsonIsArray
jsonIsObject(<jsonstr> ) : boolean //since 4.11.6: [W/L/M]
see also : jsonIsObject
jsonAsObjectHasKey(<jsonstr>,<keystr> ) : boolean //since 4.11.6: [W/L/M]
see also : jsonAsObjectHasKey
jsonAsArrayCountElements(<jsonstr> ) : intstr //since 4.11.6: [W/L/M]
see also : jsonAsArrayCountElements
jsonAsObjectCountElements(<jsonstr> ) : intstr //since 4.11.6: [W/L/M]
see also : jsonAsObjectCountElements
jsonAsArrayGetElementByIndex(<jsonstr>, <indexstr> ) : jsonstring //since 4.11.6: [W/L/M]
see also : jsonAsArrayGetElementByIndex
jsonAsObjectGetValueByKey(<jsonstr>, <keystr> ) : valuestring //since 4.11.6: [W/L/M]
see also : jsonAsObjectGetValueByKey
jsonAsObjectSetValueByKey(<jsonstr>, <keystr>,<valuestring> ) : jsonstring //since 4.11.6: [W/L/M]
see also : jsonAsObjectSetValueByKey
jsonAsObjectSetStringtypeValueByKey(<jsonstr>, <keystr>,<valuestring> ) : jsonstring //since 4.11.6: [W/L/M]
see also : jsonAsObjectSetStringtypeValueByKey
jsonAsObjectDeleteByKey(<jsonstr>, <keystr> ) : jsonstring //since 4.11.6.4: [W/L/M]
see also : jsonAsObjectDeleteByKey
jsonAsArrayPutObjectByIndex(<jsonstr>, <indexstr>, <objectstr> ) : jsonstring //since 4.11.6: [W/L/M]
see also : jsonAsArrayPutObjectByIndex
jsonAsArrayDeleteObjectByIndex(<jsonstr>, <indexstr> ) : jsonstring //since 4.11.6.4: [W/L/M]
see also : jsonAsArrayDeleteObjectByIndex
jsonAsArrayToStringList(<jsonstr> ) : stringlist //since 4.11.6: [W/L/M]
see also : jsonAsArrayToStringList
jsonAsObjectGetKeyList(<jsonstr> ) : stringlist //since 4.11.6: [W/L/M]
jsonStringListToJsonArray(<strlist> ) : jsonstr //since 4.11.6: [W/L/M]
see also : jsonAsObjectGetKeyList
see also: OpsiServiceCall OpsiServiceCall [W/L/M]
see also : OpsiServiceCall and json Related functions
see also : OpsiServiceCall Sections
opsi related functions [W/L/M]
getProductMap : stringlist // since 4.11.2.4 [W/L/M]
getProductPropertyList(<propname>,<default value> ) : stringlist //since 4.11.3 [W/L/M]
GetProductProperty (<PropertyName>, <DefaultValue> ) : string [W/L/M]
GetConfidentialProductProperty ( <PropertyName>, <DefaultValue> ) : string //since 4.11.5.2 [W/L/M]
retrieveSection (<section name> ) : stringlist [W/L/M]
Process and Script Related functions
Killtask <process name> : noresult [W/L/M]
see also : Killtask
ChangeDirectory <directory> : noresult //since 4.11.2.6 [W/L/M]
GetProcessList : stringlist //since 4.11.1.2; gives list of exename;pid;dom/user [W/L/M]
processIsRunning(<process name> ) : boolean //since 4.11.6.1 [W/L/M]
see also : processIsRunning
isProcessChildOf(<searchprocstr>, <parentprocstr>): bool //since 4.12.4.35 [W/L/M]
see also : prim-section.adoc#isProcessChildOf
shellCall (<command string> ) : noresult //since 4.11.6.1 [W/L/M]
powershellcall (<commandstr> [,<access str>='sysnative' [,<policy bool str>='true']]) : stringlist (output) //since 4.12.0.16 [W]
powershellCall(<commandstr> [,<access str>='sysnative' [,<policy bool str>='true'][, <optionstr> = '']]) : stringlist (output) //since 4.12.4.28 [W]
see also : powershellCall_list
powershellcall (<commandstr> [,<access str>='sysnative' [,<policy bool str>='true']]) : noresult //since 4.12.0.16 [W]
powershellCall(<commandstr> [,<access str>='sysnative' [,<policy bool str>='true'][, <optionstr> = '']]) : noresult //since 4.12.4.28 [W]
powershellcall (<commandstr> [,<access str>='sysnative' [,<policy bool str>='true']]) : string (exitcode) //since 4.12.0.16 [W]
powershellCall(<commandstr> [,<access str>='sysnative' [,<policy bool str>='true'][, <optionstr> = '']]) : string (exitcode) //since 4.12.4.28 [W]
see also : powershellCall_str
getOutStreamFromSection (<dos section name> ) : stringlist (output) [W/L/M]
see also : getOutStreamFromSection see also : opsi-script-ShellScript-catchout
includelog <file name> <tail size> : noresult //since 4.11.2.1 [W/L/M]
waitForPackageLock(<seconds timeout string>,<bool should we kill> ) : bool //since 4.11.6.1 [L]
see also : which
executeSection(<string expr with section call> ) //since 4.12.3.9 [W/L/M]
see also : executeSection
see also: ExecWith sections ExecWith [W/L/M]
see also: Winbatch sections Winbatch [W/L/M]
Regular expression related functions [W/L/M]:
General Info: : Regular expression related functions
isRegexMatch(<string>, <pattern>) : boolean //since 4.12.1
see also : isRegexMatch
getSubListByContainingRegex(<pattern>, <target list>) : stringlist //since 4.12.1
see also : getSubListByContainingRegex
getSubListByContainingRegex(<pattern list>, <target list>) : stringlist //since 4.12.1
getRegexMatchList(<pattern>, <target list>) : stringlist //since 4.12.1
see also : getRegexMatchList
getRegexMatchList(<pattern list>, <target list>) : stringlist //since 4.12.1
removeFromListByContainingRegex(<pattern>, <target list>) : stringlist //since 4.12.1
see also : removeFromListByContainingRegex
removeFromListByContainingRegex(<pattern list>, <target list>) : stringlist //since 4.12.1
stringReplaceRegex(<string>, <pattern>, <replacement string>) : string //since 4.12.1
see also : stringReplaceRegex
stringReplaceRegexInList(<target list>, <pattern>, <replacement string>) : stringlist //since 4.12.1
see also : stringReplaceRegexInList
Registry related functions [W]
GetRegistrystringvalue("[key] var") : string [W]
getRegistryKeyList32(<regkey> ) : stringlist //since 4.11.3 [W]
getRegistryKeyList64(<regkey> ) : stringlist //since 4.11.3 [W]
getRegistryKeyListSysnative(<regkey> ) : stringlist //since 4.11.3 [W]
getRegistryKeyList(<regkey>, <access str> ) : stringlist //since 4.12.5.0 [W]
getRegistryVarList32(<regkey> ) : stringlist //since 4.11.3 [W]
getRegistryVarList64(<regkey> ) : stringlist //since 4.11.3 [W]
getRegistryVarListSysnative(<regkey> ) : stringlist //since 4.11.3 [W]
getRegistryVarList(<regkey>, <access str> ) : stringlist //since 4.12.5.0 [W]
getRegistryVarMap32(<regkey> ) : stringlist //since 4.11.3 [W]
getRegistryVarMap64(<regkey> ) : stringlist //since 4.11.3 [W]
getRegistryVarMapSysnative(<regkey> ) : stringlist //since 4.11.3 [W]
getRegistryVarMap(<regkey>, <access str> ) : stringlist //since 4.12.5.0 [W]
RegKeyExists(<regkey>[,<access str>]) : bool //since 4.12.0.16 [W]
RegVarExists(<regkey>, <var str>[,<access str>]) : bool //since 4.12.0.16 [W]
see also: Registry [W]
see also : Registry-Sections
see also : 64 bit
String handling functions [W/L/M]
see also : string
splitString (<string1>, <string2> ) : stringlist [W/L/M]
splitStringOnWhiteSpace (<string> ) : stringlist [W/L/M]
composeString (<string list>, <Link> ) : string [W/L/M]
takeString (<index>, <list> ) : string [W/L/M]
takeFirstStringContaining(<list>,<search string> ) : string [W/L/M]
getIndexFromListByContaining(<list> : stringlist, <search string> : string ) : <number> : string //since 4.12.0.13 [W/L/M]
see also : getIndexFromListByContaining
contains(<str>, <substr> ) : bool //since 4.11.3: true if <substr> in <str> [W/L/M]
see also : contains
see also : isNumber
trim(<string> ) : string [W/L/M]
see also : trim
lower(<string> ) : string [W/L/M]
see also : lower
see also : upper
unquote(<string>,<quote-string> ) : string //since 4.11.2.1 [W/L/M]
see also : unquote
unquote2(<string>,<quote-string> ) : string //since 4.11.5.2 [W/L/M]
see also : unquote2
stringReplace(<string>, <oldPattern>, <newPattern> ) : string //since 4.11.3 [W/L/M]
strLength(<string> ) : string (number) //since 4.11.3 [W/L/M]
strPos(<string>, <sub string> ) : string (numner) //since 4.11.3 [W/L/M]
see also : strPos
strPart(<string>, <start pos>, <number of chars> ) : string //since 4.11.3 [W/L/M]
see also : strPart
see also : getValue
EscapeString: <sequence of characters> : string// [W/L/M]
see also : EscapeString
stringReplaceRegex(<string>, <pattern>, <replacement string>) : string //since 4.12.1 [W/L/M]
Stringlist handling functions [W/L/M]
see also : stringlist
getListContaining(<list>,<search string> ) : stringlist [W/L/M]
getListContainingList(<list1>,<list2> ) : stringlist //since 4.11.3.7 [W/L/M]
count (<list> ) : string (number) [W/L/M]
see also : count
emptylist (<list> ) : stringlist //since 4.11.3.7 [W/L/M]
see also : opsi-script-stringlist-iteration
createStringList (<string0>, <string1> ,… ) : stringlist [W/L/M]
reverse (<list> ) : stringlist [W/L/M]
see also : reverse
getSubList (<start index> : <end index>, <list> ) : stringlist [W/L/M]
addtolist(<list>,<string> ) : stringlist //since 4.10.8 [W/L/M]
addListToList(<dest list>,<src list> ) : stringlist //since 4.10.8 [W/L/M]
see also : jsonStringListToJsonArray
splitString(<string1>, <string2> ) : stringlist [W/L/M]
composeString(<string list>, <Link> ) : string [W/L/M]
see also : getValue
see also : editmap
areListsEqual(< strlist1>, <strlist2>, <flag> ) : boolean
see also : areListsEqual
Time / Date related functions [W/L/M]
breaks the program execution for <string> seconds. <string> has to represent an Integer Value
markTime : noresult [W/L/M]
sets a time stamp for the current system time and logs it.
see also : markTime
getDiffTimeSec : string (Time in seconds since last marktime) //since 4.11.3 [W/L/M]
timeStampAsFloatStr : string (Floating Number - format: 'days.decimal days') //since 4.11.6 [W/L/M]
see also : timeStampAsFloatStr
Usercontext / loginscripts related functions [W]:
GetUserSID(<Windows Username> ) : string
GetLoggedInUser : string //since 4.11.1.2
GetUsercontext : string //since 4.11.1.2
GetScriptMode : string possible values 'Machine','Login' //since 4.11.2.1
see also : GetScriptMode
saveVersionToProfile : noresult - save productversion-packageversion to local profile //since 4.11.2.1
see also : opsi-script-xml2-functions
getXml2DocumentFromFile(<path to xml file> ) : xml2stringlist //since 4.12.1
see also : getXml2DocumentFromFile
getXml2Document(<stringlist wit xml> ) : xml2stringlist //since 4.12.1
xml2GetFirstChildNodeByName(<xml2stringlist>, <node name str> ) : xml2stringlist //since 4.12.1.
see also : xml2GetFirstChildNodeByName
getXml2UniqueChildnodeByName(<xml2stringlist>, <node name str> ) : xml2stringlist //since 4.12.1.
see also : getXml2UniqueChildnodeByName
getXml2AttributeValueByKey(<xml2stringlist>, <attr name str> ) : string //since 4.12.1.
see also : getXml2AttributeValueByKey
getXml2Text(<xml2stringlist> ) : string //since 4.12.1.
see also : getXml2Text
see also : XML2 Sections [W/L/M]
TOML files related functions [W/L/M]:
see also : opsi-script-toml-functions
SaveToTOMLFile(<TOMLcontents: String> , <TOML file Path: String> ) : boolean //since 4.12.5
ConvertTOMLfileToJSONfile(<TOMLfilePath: String> , <JSONfilePath: String> ) : boolean //since 4.12.5
