opsi subscriptions
Initial Deployment of opsi subscriptions
To provide the required packages, you can download them manually or install all packages after editing the configuration of the opsi-package-updater.
Configuration of the opsi-package-updater / updating the opsi subscriptions
For further operation it is recommended to save the repository configuration in '/etc/opsi/package-updater.repos.d/'. You will receive a corresponding configuration file with your access data.
If using a proxy, the access must be configured in these files!
It then offers to ony install the required packages from the new repositories:
# Example: Install packages for mshotfix, OS Windows 10 x64 2009-22h2 / Server 2016 / 2019 / 2022 / Windows 11 22H2/23H2
opsi-package-updater --repo uib_abo_mshotfix install mshotfix mshotfix-win10-2009-x64-glb mshotfix-win10-1607-x64-glb mshotfix-win10-1809-x64-glb mshotfix-win2022 mshotfix-win11-22h2
# Example: Install packages for Office 2016
opsi-package-updater --repo uib_abo_msoffice install office_2016_hotfix
# Example: Install packages for the standard opsi products: firefox and libreoffice
opsi-package-updater --repo uib_abo_standard install firefox libreoffice
It is possible to install only required packages, e.g. only the packages to update Windows 1022h2 and Windows 11 22h2/23H2:
opsi-package-updater -v install mshotfix mshotfix-win10-2009-x64-glb mshotfix-win11-22h2
To update the packages the usage of opsi-package-updater is recommended.
By executing opsi-package-updater -v update you can update the installed packages, for example via a cronjob.
An equivalent is to update the packages for each repository:
# Updating packages for mshotfix
opsi-package-updater --repo uib_abo_mshotfix update
# Updating packages for msoffice
opsi-package-updater --repo uib_abo_msoffice update
# Updating packages for standard products
opsi-package-updater --repo uib_abo_standard update
Configuration of default properties
When an opsi package is first installed on an opsi depot server, the product properties for the depot server are set to the default values defined in the package. These values then apply to all clients of the depot, provided they are not overwritten by individual values. If a newer package version is subsequently installed using opsi-package-manager or opsi-package-updater, the default values set for the depot are retained. The respective default values for the depot can be changed at any time via the management interface opsi-configed.
Subscription 'MS-Hotfixes'
Regular updates for the product MS-Hotfix (OS hotfixes for Windows 10 / Windows 2016 / Windows 2019 / Windows 2022 / Windows 11).
Versions no longer supported by Microsoft are displayed as "failed": 1507 "non"-LTSB, 1511 and 1607 "non"-LTSB except Education and Enterprise versions.
The updates will be available within three working days after the release of a patch that Microsoft considers to be important or critical.
Rating Description
Critical
A vulnerability whose exploitation could allow code execution without user interaction. These scenarios include self-propagating malware (e.g. network worms), or unavoidable common use scenarios where code execution occurs without warnings or prompts. This could mean browsing to a web page or opening email. Microsoft recommends that customers apply Critical updates immediately.
Important
A vulnerability whose exploitation could result in compromise of the confidentiality, integrity, or availability of user data, or of the integrity or availability of processing resources. These scenarios include common use scenarios where client is compromised with warnings or prompts regardless of the prompt’s provenance, quality, or usability. Sequences of user actions that do not generate prompts or warnings are also covered. Microsoft recommends that customers apply Important updates at the earliest opportunity.
Moderate
Impact of the vulnerability is mitigated to a significant degree by factors such as authentication requirements or applicability only to non-default configurations. Microsoft recommends that customers consider applying the security update.
Low
Impact of the vulnerability is comprehensively mitigated by the characteristics of the affected component. Microsoft recommends that customers evaluate whether to apply the security update to the affected systems.
The opsi-mshotfix package uses (like WSUS Offline Update http://forums.wsusoffline.net/viewtopic.php?f=7&t=172 coverage of WSUS Offline Update) to download Microsoft’s update catalog file wsusscn2.cab, to identify the required patches. This catalog file contains at least all the "critical" and "security-relevant" updates, but not necessarily all the "important" and "optional" updates.
The opsi mshotfix packages have a modular structure. The basic package "mshotfix" contains only a script for installing the patches. The actual patches are contained in separate packages.
Table 1. mshotfix Client Requirements
OS
Windows 11
WAN/VPN extension: The packages for Windows 11 / Server 2022 require opsi-client-agent >= 4.2.0.43-1 and opsiclientd >= 4.2.0.43-1
Structure of the subscription area on our download server:
mshotfix
  !-opsi4/
     !-glb/	Base-package mshotfix and global packages
		  mshotfix-win10-1507-x64-glb
		  mshotfix-win10-1507-x86-glb
		  mshotfix-win10-1607-x86-glb
		  mshotfix-win10-1809-x86-glb
		  mshotfix-win10-2009-x86-glb
			mshotfix-win2022
			mshotfix-win11-21h2
			mshotfix-win11-22h2
     !-misc/	various additional packages
     		dotnetfx
The following table should help you choose the right packages:
Table 2. mshotfix Client-OS
OS
Arch
Patch-package
Windows 10
32Bit
mshotfix-win10-x86-glb or the matching modular package
Windows 10
64Bit
mshotfix-win10-win2016-x64-glb or the matching modular package
Windows 2016
64Bit
mshotfix-win10-win2016-x64-glb or mshotfix-win10-1607-x64-glb
Windows 2019
64Bit
mshotfix-win10-win2016-x64-glb or mshotfix-win10-1809-x64-glb
Windows 10 1507 LTSB
32/64Bit
mshotfix-win10-1507-x86-glb mshotfix-win10-1507-x64-glb
Windows 10 1607 LTSB / Windows Server 2016
32/64Bit
mshotfix-win10-1607-x86-glb mshotfix-win10-1607-x64-glb
Windows 10 1809 LTSC / Windows Server 2019
32/64Bit
mshotfix-win10-1809-x86-glb mshotfix-win10-1809-x64-glb
Windows 10 2009/21h2/22h2
32/64Bit
mshotfix-win10-2009-x86-glb mshotfix-win10-2009-x64-glb
Windows Server 2022
64Bit
mshotfix-win2022
Windows 11 21h2
64Bit
mshotfix-win11-21h2
64Bit
mshotfix-win11-22h2
Installation:
opsi-package-manager -i mshotfix_201008-1.opsi
To set to setup wherever the product is installed:
opsi-package-manager -iS mshotfix_201008-1.opsi
In addition to the basic package, the patch packages are installed in the same way. However, since these packages do not contain any installation scripts, they can only be used together with the basic package, i.e. you cannot set them separately on setup. The mshotfix basic package is responsible for the client installation.
Since package mshotfix 201304-1, a list of patches installed by mshotfix is stored locally in the file C:\opsi.org\mshotfix\deployed.txt.
Caution
Since package mshotfix 201808-3, the current Servicing Stack is installed first, followed by an immediate reboot.
noreboot
noreboot=on: Don’t Reboot if possible Warning will be logged if a reboot is required. Will be ignored for Servicing stacks values: ["off", "on"] default: ["off"]
force
force=on: All Hotfixes will be forced installed values: ["off", "on"] default: ["off"]
excludes
Commaseparated list with kb-numbers or ms-no, that will be excluded (Only Number without beginning kb and no spaces. Example: 123456,789011,976002
severity
choose the severity that will be installed. Possible Entries are Critical, Important, Moderate, all values: ["Critical", "Important", "Moderate", "all"] default: ["Critical", "Important"]
excludelist-superseded.txt
Use File ExcludeList-superseded.txt values: ["", "ExcludeList-superseded.txt"] default: [""]
monthly-updates
Handle windows-7-and-windows-8-1 : security Only Quality Update vs Monthly Quality Rollup (see Further simplifying servicing models for Windows 7 and Windows 8.1, More on Windows 7 and Windows 8.1 servicing changes, .NET Framework Monthly Rollups Explained) values: ["all", "monthly_quality_rollup", "security_only_quality_update"] default: ["security_only_quality_update"]
misc mshotfix-uninstall
mshotfix-uninstall        201512-1                  MS Hotfix BasePackage
Removes patches that can be uninstalled via wusa /uninstall …​.
excludes
Commaseparated list with kb-numbers or ms-no, that will be excluded (Only Number without beginning kb and no spaces. Example: 2553154,ms14-082)
extrareboot
for local-image and wim-capture: make two extrareboots to ensure windows is really finished with configure windows / trusted installer. Verify checks if updates with ExitCode 3010 really installed, needs one more reboot and may show erroneously failed values: ["False","True","Verify"] default: ["False"]
noreboot
noreboot=on: Don’t Reboot. Warning will be logged if a reboot is required. values: ["off", "on"] default: ["off"]
removefromdeployed.txt
Remove from deployed.txt default: False
removekb
Remove KBXXXXX, (Only Number without beginning kb and no spaces f.e. 3097877) multivalue: True default: [""]
misc dotnetfx
dotnetfx                  22631.4.8.1-1                 .NET Framework
Package for installing NET Framework versions 4.6.2 and higher. NET 3.5 can also be installed
version
The Microsoft .NET Framework 4.8 is a highly compatible, in-place update to the Microsoft .NET Framework 4, 4.5, 4.5.1, 4.5.2, 4.6, 4.6.1, 4.6.2, 4.7 , 4.7.1 and 4.7.2
values: ["3.5", "4.6.2", "4.7", "4.7.1", "4.7.2","4.8","4.8.1","latest", "latestAnd3.5"]
default: ["latest"]
install_language_languagepack
install_language_languagepack values: ["auto", "de", "en", "fr"] default: ["auto"]
os-package
Here you can switch from which OS-Version to be install Dotnet3.5, auto=win10 or opsi-local-image-win10 (default); other ProductID for netboot-product values: ["auto", ] default: ["auto"]
Update subscription for 'MS-Office Hotfixes'
Regular updates for MS Office 2013/2016 32 bit/64 bit.
Table 3. Office hotfix Requirements
Office Version
required
Office 2013
Servicepack 1
Office 2016
Updates for MS Office 2013 32-bit international: office_2013_hotfix
office_2013_hotfix               202309-1                  Microsoft Office 2013 Hotfixes
Contains language-independent monthly Office 2013 hotfixes (including Visio 2013). Requires Service Pack 1.
Is tested with Office 2013 Professional
A list of patches installed by office_2013_hotfix is stored locally in the file C:\opsi.org\mshotfix\office_2013_hotfix_deployed.txt.
Since office_2013_hotfix 201503-1:
excludes
Comma separated list with kb-numbers or ms-no, that will be excluded (Only Number without beginning kb and no spaces. Example: 2553154,ms14-082)
Updates for MS Office 2016 32-bit international: office_2016_hotfix
office_2016_hotfix               202312-1                  Microsoft Office 2016 Hotfixes
Contains language-independent monthly Office 2016 hotfixes (including Visio 2016).
Is tested with Office 2016 Professional
A list of patches installed by office_2016_hotfix is stored locally in the file C:\opsi.org\mshotfix\office_2016_hotfix_deployed.txt.
excludes
CAUTION
If you want to install updates for MS Office 2016 32-bit and 64-bit, or only 64-bit:
Configure the repo uib_abo_msoffice update section: x3264 / x64
Update subscription for the opsi standard packages
Regular product updates for:
Adobe Reader DC Classic / Continuous (international, 32 Bit)
Apache OpenOffice.org (German, 32 Bit)
Google Chromium for business (international, 32 Bit / 64 Bit)
LibreOffice (international, 32 Bit / 64 Bit)
Mozilla Firefox (German, English, French and Dutch, 32 Bit), respectivly as 32/64 Bit package since 201706
Mozilla Thunderbird (German, English and French, 32 Bit)
Java VM (javavm) based on Open JDK LTS 11 / 17 (international, 64 Bit)
Java VM 8 (javavm8) based on Open JDK LTS 8 (international, 32 Bit / 64 Bit)
Java VM (javavm-oracle-jdk) OpenJDK based on the actual open jdk implementation (international, 64 Bit)
Depending on contract, we also provide the following languages ​​as subscriptions:
Mozilla Firefox (additionally in Czech, Danish, Italian, Norwegian or Spanish, 32 Bit)
Mozilla Thunderbird (additionally in Italian, 32 Bit)
Other languages on request.
The update will be available within two working weeks after the release of an update of these products. For security updates classified as critical by the manufacturer within one working week.
Customizing with central configuration files
For the opsi-packages
adobe.reader.dc.classic
adobe.reader.dc.continuous / adobe.reader.dc.x64
firefox
thunderbird
there is the possibility to create your own configurations and store them in the directory custom, which can be selected via properties. (See below for details)
Customizing with preinst/postinst-scripts
firefox
google-chrome-for-business
javavm	/	javavm8 / javavm-oracle-jdk
libreoffice
ooffice
thunderbird
there is the possibility to store your own custom scripts in the directory custom\scripts.
Simple templates for the supported scripts can be found in the directory opsi\scripts.
custom.actions.post.setup
custom.actions.post.uninstall
custom.actions.pre.setup
custom.actions.pre.uninstall
custom.declarations
custom.sections
custom scripts will be included in
- setup-script
- uninstall-script
custom pre-scripts will be included in
- setup-script
- uninstall-script
custom post-scripts will be included in
- in setup-script
- uninstall-script
custom.declarations
; intended for declaration of custom Variables and Stringlist Variables
; will be included with "include_insert" at top of [actions]
; but after GetProductProperties
custom.sections
; intended for declaration of custom secondary sections
; will be included with "include_append" at top of [actions]
custom.actions.pre.setup  (or custom.actions.pre.uninstall)
; will be included with "include_insert" at at top of [actions]
; (but after GetProductProperties)
custom.actions.post.setup (or custom.actions.post.uninstall)
; will be included with "include_insert" in case of successful installation before "endof_"actions"
; in setup-script ( or uninstall-script)
Adobe Acrobat Document Cloud Classic : adobe.reader.dc.classic
adobe.reader.dc.classic		20202000530418-1		Adobe Acrobat Reader DC classic
The adobe.reader.dc.classic-Package contains Adobe Acrobat Document Cloud Classic (MUI-Version)
Adaptation in the transform file *.mst
cat transform.txt
Changes vs default the transform file *.mst
Personalization Options
Suppress Eula
Installation Options
acivated - Make Reader the default PDF viewer
IF REBOOT REQUIRED - suppress reboot
Shortcuts
deactivated - Destination Computer/Desktop/Adobe Reader XI (Icon)
Online and Acrobat.com Features
Online Features
activated - Disable product updates
Enable & Ask before Installing - Load trusted root certificates from Adobe
Online Services and Features
disable product updates
Load trusted root certificates from Adobe disable
DISABLE all Services
adobereader.mst
The Adobe Reader package from uib uses a standard transform file created with the Adobe Customization Wizard. Additionally, custom MST files can be stored in the directory /var/lib/opsi/depot/adobe.reader.dc.classic/custom on the share opsi_depot. These can be selected via this property (after reinstalling package using opsi-package-manager -i <adobe-package>).
When importing the adobe.reader.dc.classic package on the opsi server, the custom directory is retained using a preinst/postinst-script.
opsi WAN/VPN extension: The package must be reinstalled with 'opsi-package-manager' after changes in the custom directory, so that the file <productid>.files is updated.
client_language
The adobe.reader.dc.classic-package contains Adobe Acrobat Document Cloud Classic (MUI-Version) "auto" tries to install the correct language. values: ["auto", "de", "en", "fr"] default: ["auto"]
classicversion
description: https://helpx.adobe.com/acrobat/release-note/release-notes-acrobat-reader.html Classic Track (2015 Release) or (2017 Release) values: ["2020"] default: ["2020"]
disableadobeacrobatupdateservice
Disable Adobe Acrobat Update Service and remove Adobe Acrobat Update Task values: ["false", "true"] default: ["false"]
removebeforesetup
remove target version of adobe reader before install values: ["false", "true"] default: ["false"]
noreboot
description: noreboot=true: Don’t Reboot. Warning will be logged if a reboot is required. values: ["false", "true"] default: ["false"]
Adobe Acrobat Document Cloud Continuous : adobe.reader.dc.continuous / adobe.reader.dc.x64
adobe.reader.dc.continuous	232300820458-1							Adobe Acrobat Reader DC Continuous (MUI-Version)
adobe.reader.dc.x64        23.008.20458-1            Adobe acrobat reader (MUI-Version) x64
The adobe.reader.dc.classic-Package contains Adobe Acrobat Document Cloud Continuous (MUI-Version)
cat transform.txt
Suppress Eula
Shortcuts
deactivated - Destination Computer/Desktop/Adobe Reader (Icon)
Online Features
adobereader.mst
The Adobe Reader package from uib uses a standard transform file created with the Adobe Customization Wizard. Additionally, custom MST files can be stored in the directory /var/lib/opsi/depot/adobe.reader.dc.continuous/custom on the share opsi_depot. These can be selected via this property (after reinstalling package using opsi-package-manager -i <adobe-package>).
When importing the adobe.reader.dc.continuous package on the opsi server, the custom directory is retained using a preinst/postinst-script.
client_language
removebeforesetup
noreboot
Google Chromium for Business
google-chrome-for-business	120.0.6099.200-1
This package contains the msi installer from Google (see Chrome for Business FAQ https://support.google.com/chrome/a/answer/188447?hl=en )
remarks:
The uninstallation and installation of google-chrome.msi sometimes fails.
Therefore there are different approaches in the opsi package to increase the reliability of the installation.
One customer reported a success rate of 100% for 40 installations with the following property settings:
  • install_architecture: 32
  • reboot_on_retry: True
  • reboot_after_uninstall: True
  • timeout: 240
In our internal tests we use: * install_architecture: system specific * reboot_on_retry: True * reboot_after_uninstall: True * timeout: notimeout
autoupdate
!!! Will not work anymore!!!
ADM= use Policy based on Googles Template, 0=UpdatesDisabled, 1=UpdatesEnabled, 2=ManualUpdatesOnly, 3=AutomaticUpdatesOnly, values: ["0", "1", "2", "3", "ADM"] default: ["0"]
disablescheduledtaskgoogleupdatemachine
Disable scheduled task GoogleUpdateTaskMachineCore and GoogleUpdateTaskMachineUA values: ["false", "true"] default: ["true"]
removeupdatehelper
default: ["true"]
description: which architecture (32/64 bit) has to be installed values: ["32", "64", "system specific"] default: ["system specific"]
reboot_on_retry
description: If installation fails and (timeout > 0) then reboot before retry default: False
description: reboot after uninstall old version default: False
timeout
description: TimeOutSeconds msi installs values: ["240", "300", "600", "notimeout"] default: ["notimeout"]
Apache OpenOffice : ooffice4
ooffice						4.1.15-1									Apache OpenOffice
The ooffice package contains Apache OpenOffice in German.
handle_excel_xls
Should OpenOffice be used as the default for MS Excel documents? on = OpenOffice.org will be used as the default for MS Excel documents off = OpenOffice.org will not be used as the default for MS Excel documents
handle_powerpoint_ppt
Should OpenOffice be used as the default for MS Powerpoint documents? on = OpenOffice.org will be used as the default for MS Powerpoint documents off = OpenOffice.org will not be used as the default for MS Powerpoint documents
handle_word_doc
Should OpenOffice be used as the default for MS Word documents? on = OpenOffice.org will be used as the default for MS Word documents off = OpenOffice.org will not be used as the default for MS Word documents
LibreOffice The Document Foundation : libreoffice
libreoffice					7.5.9or7.6.4-1							LibreOffice
The libreoffice package contains LibreOffice international.
client_language
client_language - only for messages important, cause libre office is international values: ["auto", "de", "en", "fr"]
desktop_shortcuts
description: desktop_shortcuts for writer,base.calc,impress values: ["calc","draw","impress","none","writer"] default: ["none"]
hide_component
description: Hide component base by removing desktoplink and exe file values: ["base", "none"] default: ["none"]
libreoffice-version
description: 'Stable' - is an Extended Support Release from LibreOffice for the conservative user - default version (7.5.9); 'Experimentell' is a version for the experimentell user from LibreOffice (7.6.4) values: ["experimentell", "stable"] default: ["stable"]
msoregister
Open Microsoft Office documents with LibreOffice (true) values: ["false", "true"] default: ["false"]
remove_save_mode_link
description: Remove LibreOffice (Safe Mode).lnk values: ["false","true"] default: ["false"]
res-xcd-file
description: additional res-xcd-file to use for dir share registry res see https://www.allianz-fuer-cybersicherheit.de/SharedDocs/Downloads/Webs/ACS/DE/BSI-CS/BSI-CS_147.pdf?__blob=publicationFile&v=6
ui_languages
description: which UI languages should be installed (comma separated), For example UI_LANGS=en_US,de,fr,hu will install English (US), German, French, and Hungarian. default: ["auto"]
which architecture (32/64 bit) has to be installed values: ["32", "64", "system specific"] default: ["32"]
Mozilla Firefox : firefox
firefox						115.6.0esror121.0-1
The firefox-package contains Mozilla Firefox in German, Englisch, French and Dutch.
All by Mozilla supported versions are provided.
Firefox can be configured centrally a) either via a central configuration file mozilla.cfg (see http://kb.mozillazine.org/Locking_preferences) b) or via a policies.json (see https://github.com/mozilla/policy-templates/blob/master/README.md)
which must be placed in the following directory:
/var/lib/opsi/depot/firefox/custom/
When the package is installed again using opsi-package-manager -i <firefox-paket>, the configuration files found are retained via the preinst/postinst-mechanism and can then be selected using the "mozillacfg" property.
  • example:
    cat /var/lib/opsi/depot/firefox/custom/mozilla.cfg
    lockPref("browser.startup.homepage", "http://www.uib.de");
    lockPref("network.proxy.type", 1);
    lockPref("network.proxy.http", "router.uib.local");
    lockPref("network.proxy.http_port", 3128);
As an alternative to a mozilla.cfg, you can also integrate an autoconfig.zip created with the CCK2 using the property "mozillacfg".
client_language
values: ["auto", "de", "en", "fr", "nl"] default: ["auto"]
firefox-version
Firefox 'esr' - Extended Support Release from Mozilla.org, standard is the newest version values: ["esr", "standard"] default: ["esr"]
commandlineoptions
starts firefox with the supplied parameters. See https://developer.mozilla.org/en-US/docs/Mozilla/Command_Line_Options values: ["", "-no-remote -Profile H:\\ProfileDir"] default: [""]
pref_file
in which file should the settings be made, user.js or prefs.js. values: ["prefs", "user"] default: ["prefs"]
noautoupdate
(on/off): disable auto update. default=on
setproxy
(off/direct/manual/file) proxy settings
  • off= do nothing
  • direct = direct connection to the internet
  • manual = use proxy settings via property proxysetting (<ip-address>:<port>) and property noproxy_hosts (host1,host2)
  • file = use proxy settings via property proxysetting (<path_to_proxyconf.pac>) and property noproxy_hosts (host1,host2)
  • system
  • default=off
proxysetting
string for proxy setting (see: setproxy)
noproxy_hosts
comma separated list of hosts
mozillacfg
description: filename for mozilla.cfg in %scriptpath%\custom-directory, http://kb.mozillazine.org/Locking_preferences
profilemigrator
enable or disable Profilemigrator on first run values: ["off", "on"] default: ["off"]
  • Known problems:
    • Installation via "On Demand" may fail if Firefox is running.
Mozilla Thunderbird : thunderbird
thunderbird					115.6.0-1
The thunderbird-package contains Mozilla Thunderbird in German, English and French.
Similar to the Firefox package, a central configuration file can be provided.
client_language
thunderbird-version
values: ["115.x"] default: ["115.x"]
commandlineoptions
starts thunderbird with the supplied parameters. See https://developer.mozilla.org/en-US/docs/Mozilla/Command_Line_Options values: ["", "-no-remote -Profile H:\\ProfileDir"] default: [""]
addonsactivation
description: Enable/Disable AddOns (default = enable) values: ["off", "on"] default: ["on"]
Set_Netscape_User_Pref ("extensions.autoDisableScopes", 11)
Set_Netscape_User_Pref ("extensions.shownSelectionUI", true)
enigmail
description: Install GnuPG-Plugin values: ["off", "on"] default: ["off"]
noautoupdate
description: disable automatic updates values: ["off", "on"] default: ["on"]
mozillacfg
lightning
description: Install calender plugin lightning values: ["off", "on"] default: ["off"]
  • Known problems:
    • Installation via "On Demand" may fail if thunderbird is running.
Open JRE / JDK 11 LTS / JDK 17 LTS : javavm
javavm						11.0.21or17.0.9-1         JDK 11 or 17
The javavm-package contains the Open JDK 11 LTS implementations from SAP (SapMachine) and Amazon (Amazon Corretto) because Oracle no longer provides a freely available Java runtime (since early January 2019).
(Oracle announced "End Of Public Updates February 2019" http://www.oracle.com/technetwork/java/eol-135779.html)
description: which architecture (32/64 bit) has to be installed values: ["64 only"] default: ["64 only"]
javaversion
description: which version has to be installed jre 11 Sapmachine, JDK 11 amazon corretto or JDK 17 amazon corretto values: ["17amazoncorretto","jdkamazoncorretto", "jdksap"] default: ["jdksap"]
keepversion
description: Don’t uninstall jre version values: ["1.6.0_0", "1.6.0_1", "1.6.0_2", "1.6.0_3", "1.6.0_4", "1.6.0_5", "1.6.0_6", "1.6.0_7", "none"] default: ["none"]
uninstalljava16
description: Uninstall Java 1.6 "Patch in Place" Installations default: True
uninstalljava17
description: Uninstall Java 1.7 "Patch in Place" Installations default: True
environment_set_java_home
Set the environment variable JAVA_HOME default: False
OpenJDK 8 LTS : javavm8
javavm8						1.8.0.392-1					JDK 8 LTS
The javam8 package contains the Open JDK 8 LTS implementations from Amazon (Amazon Corretto)
javaversion
which version has to be installed amazon 352 values: ["jdkamazoncorretto"] default: ["jdkamazoncorretto"]
which architecture (32/64 bit) has to be installed values: ["32 only", "64 only", "both", "system specific"] default: ["system specific"]
keepversion
uninstalljava16
uninstalljava17
OpenJDK : javavm-oracle-jdk
javavm-oracle-jdk			21.0.1-1								Open JDK
The javavm-oracle-jdk-package contains the current Open JDK implementation from Oracle http://jdk.java.net/
keepversion
uninstalljava16
uninstalljava17
