opsi-script reference card (4.12.13)
For Windows [W], Linux [L] and MacOS [M]
Global text constants
System directories
System directories [W]:
%ProgramFilesDir%
: 'c:\program files (x86)' at 64 Bit
%ProgramFiles32Dir%
: 'c:\Program Files (x86)' at 64 Bit //since 4.10.8
%ProgramFiles64Dir%
: 'c:\program files' at 64 Bit //since 4.10.8
%ProgramFilesSysnativeDir%
%Systemroot%
: 'c:\windows'
%System%
: 'c:\windows\system32' at 32/64 Bit
%Systemdrive%
: 'c:'
%ProfileDir%
NT5: 'c:\Documents and Settings'
NT6: 'C:\users'
Common (AllUsers) directories [W]:
%AllUsersProfileDir%
or %CommonProfileDir%
NT5: 'c:\Documents and Settings\All Users'
NT6: 'C:\Users\Public'
%CommonStartMenuPath%
or %CommonStartmenuDir%
NT5: 'c:\Documents and Settings\All Users\Startmenu'
NT6: 'C:\ProgramData\Microsoft\Windows\Start Menu'
%CommonAppdataDir%
NT5: 'c:\Documents and Settings\All Users\Application Data'
NT6: 'C:\ProgramData'
%CommonDesktopDir%
NT5: 'c:\Documents and Settings\All Users\Desktop'
NT6: 'C:\Users\Public\Desktop'
%CommonStartupDir%
NT5: 'c:\Documents and Settings\All Users\Autostart'
NT6: 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp'
%CommonProgramsDir%
NT6: 'C:\ProgramData\Microsoft\Windows\Start Menu\Programs'
see also : Common (AllUsers) directories [W]
Default User directories [W]:
%DefaultUserProfileDir%
: 'C:\Users\Default' //since 4.11.1.1
see also : Default User Directory [W]
Current user directories [W]:
User is the logged in user or given by /usercontext.
%AppdataDir%
or %CurrentAppdataDir%
: //since 4.10.8.13
NT6: 'c:\Users\%USERNAME%\Appdata\Roaming'
%CurrentStartmenuDir%
//since 4.10.8.13
'C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\Start Menu'
%CurrentDesktopDir%
//since 4.10.8.13
'C:\Users\<user name>\Desktop'
%CurrentStartupDir%
//since 4.10.8.13
'C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup'
%CurrentProgramsDir%
//since 4.10.8.13
'C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs'
%CurrentSendToDir%
//since 4.10.8.13
'C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\SendTo'
%CurrentProfileDir%
//since 4.11.2.1
'C:\Users\<user name>'
/AllUserProfiles directory constants [W/L/M]:
%UserProfileDir%
or
%CurrentProfileDir%
// since 4.11.2.1
NT5: 'c:\Documents and Settings\%USERNAME%'
NT6: 'c:\users\%USERNAME%'
opsi-script Path and Directories [W/L/M]:
%ScriptPath% or %ScriptDir%
%RealScriptPath%
(since 4.12.4.21)
%ScriptDrive%
%OpsiscriptDir%
(since 4.12.3.6), %WinstDir%
%OpsiscriptVersion%
(since 4.12.3.6), %WinstVersion%
(since 4.10.8.3)
%opsiscriptProcname%
(since 4.12.4.35)
%Logfile%
%opsiScriptHelperPath%
'%ProgramFiles32Dir%\opsi.org\opsiScriptHelper\lib' // since 4.11.3.2
%opsiTmpDir%
: 'c:\opsi.org\tmp' // since 4.11.4.3
%opsiUserTmpDir%
: 'c:\opsi.org\usertmp' // since 4.12.4.37
%opsiLogDir%
: 'c:\opsi.org\log' // since 4.11.4.3
%opsidata%
: 'c:\opsi.org\data' // since 4.12.0.12
%opsiapplog%
: 'c:\opsi.org\applog' // since 4.12.0.12
see also : opsi-script Path and Directory [W/L/M]
Network informations [W/L/M]:
%Host%
: value of environment variable HOST.
%PCName%
: value of environment variable PCNAME, or if absent of COMPUTERNAME.
%Username%
: Name of actual user.
%IPName%
: The dns name of the pc. Usually identical with the netbios name and therefore with %PCName%
besides that the netbios names uses to be uppercase.
%IPAddress%
: may be the IP-Address of the machine. Use funktion GetMyIpByTarget()
instead.
see also : GetMyIpByTarget
see also : Network Information [W/L/M]
Service Data [W/L/M]
%HostID%
: FQDN of the client in opsi service context, otherwise the computer name
%FQDN%
: FQDN in network context
%opsiserviceURL%
%opsiServer%
%opsiDepotId%
//since 4.11.4
%opsiserviceUser%
FQDN used for the connection to the opsi-config-server
%opsiserviceClientId%
: command line option /clientid
%opsiservicePassword%
%installingProdName%
: productid //since 4.10.8
%installingProdVersion%
: product version //since 4.10.8
%installingProduct%
: productid (deprecated)
see also : Data for and from opsi service [W/L/M]
Functions to handle constants [W/L/M]
replaceOpsiConstants(
<string list> ) : stringlist
//since 4.12.3.6 [W/L/M]
see also : replaceOpsiConstants_list
<string> ) : string
see also : replaceOpsiConstants_string
In Primary Sections
Kinds of Primary Sections [W/L/M]:
[Initial]
[sub
<identifier> ]
sub
<file name>
[ProfileActions]
[W]
opsi-script control [W/L/M]:
encoding=
<encoding> // (default is system encoding) since 4.11.4.2
see also : encoding
LogLevel
(deprecated)
see also : Specification of Logging Level [W/L/M]
SetLogLevel
= <number> or SetLogLevel
= <string> // (default=6)
see also : SetLogLevel
SetLogLevel = 7
SetLogLevel = "7"
ExitOnError
= <boolean value> // (default=false)
see also : ExitOnError
ScriptErrorMessages =
<boolean value> // (default=true)
see also : ScriptErrorMessages
see also : Central configuration via opsi Configs
FatalOnSyntaxError =
<boolean value> // (default=true) since 4.11.3.2
see also : FatalOnSyntaxError
FatalOnRuntimeError =
<boolean value> // (default=false) since 4.11.3.2
see also : FatalOnRuntimeError
AutoActivityDisplay =
<boolean value> // (default=false); if true shows a marquee (endless) progressbar while winbatch/ShellScript sections are . //since 4.11.4.7
see also : AutoActivityDisplay
forceLogInAppendMode =
<boolean value> // (default=false); if true, log will be send in append mode . //since 4.12.3.6
see also : forceLogInAppendMode
Message
<string> or Message
= <const string>
see also : Message
ShowMessageFile
<string>
see also : ShowMessageFile
ShowBitMap
[<file name>] [<sub title>]
see also : ShowBitMap
comment
<string> or comment
= <const string>
see also : comment
LogError
<string> or LogError
= <const string>
see also : LogError
LogWarning
<string> or LogWarning
= <const string>
see also : LogWarning
includelog
<file name> <tail size> //since 4.11.2.1 [W/L/M]
see also : includelog
includelog
<file name> <tail size> [<encoding>] //since 4.11.4.1 [W/L/M]
includelog "%Scriptpath%\test-files\10lines.txt" "5"
SetConfidential
<secret string> //since 4.11.3.5 [W/L/M]
see also : SetConfidential
asConfidential(
<secret string expression> ) : string
//since 4.12.0.16 [W/L/M]
see also : asConfidential_str
asConfidential(
<secret stringlist expression> ) : stringlist
//since 4.12.4.15 [W/L/M]
see also : asConfidential_list
Pause
<string> or Pause
= <const string>
see also : Pause
Stop
<string> or stop
= <const string>
see also : Stop
include_insert
<file name> // since 4.11.3
see also : include_insert
include_append
see also : include_append
NormalizeWinst
// (set normal window state) since 4.11.3
see also : NormalizeWinst
IconizeWinst
// (set minimized window state)
see also : IconizeWinst
MaximizeWinst
// (set maximized window state) // since 4.11.5.1
see also : MaximizeWinst
RestoreWinst
// (restore last window state)
see also : RestoreWinst
SetSkinDirectory
<path to skin.ini> // since 4.11.3.5
see also : SetSkinDirectory
runningInWanMode
: boolean //since 4.12.4.17 [W/L/M]
see also : runningInWanMode
reloadProductList
//since 4.12.6.1 [W/L/M]
see also : reloadProductList
Variables [W/L/M]:
Strings
DefVar
<variable name> // since 4.12.4.32 also possible:
DefVar
<variable name> [= <inital value>]
Set
<variable name> =
<value>
see also : String (or Text) Variables [W/L/M]
Stringlists
DefstringList
<variable name>
; since 4.12.4.32 also possible:
DefstringList
see also : Stringlist Variables [W/L/M]
Functions
String functions
Important
GetOS
// 'Linux' or 'Windows_NT' [W/L/M]
see also : GetOS
getLinuxDistroType
// 'debian' or 'redhat' or 'suse' (see getLinuxVersionMap
) [L]
see also : getLinuxDistroType
GetMsVersionInfo
//Windows Version Information [W]
see also : GetMsVersionInfo
GetMsVersionName
see also : GetMsVersionName
GetSystemType
//OS Architecture ("64 Bit System" or "x86 System") [W/L/M]
see also : GetSystemType
getOSArchitecture
// OS Architecture (x86_32 / x86_64/ arm_64) //since 4.12.4.17 [W/L/M]
see also : getOSArchitecture
getRegistryValue(
<keystr>, <varstr> )
: string //since 4.12.0.16 [W]
<access str> = one of 32bit, 64bit, sysnative ; default sysnative
see also : getRegistryValue
GetRegistrystringvalue ("[key] var")
: string [W]
see also : GetRegistrystringvalue
GetRegistryStringValue32 ("[key] var")
: string //since 4.10.8 [W]
see also : GetRegistryStringValue32
GetRegistryStringValue64 ("[key] var")
see also : GetRegistryStringValue64
GetRegistryStringValueSysNative ("[key] var")
see also : GetRegistryStringValueSysNative
GetValueFromInifile (
<file path>, <section>, <key>, <default value>[, <encoding>])
: string [W/L/M]
see also : GetValueFromInifile
GetProductProperty (
<PropertyName>, <DefaultValue> )
[W/L/M]
see also : GetProductProperty
GetConfidentialProductProperty (
//since 4.11.5.2 [W/L/M]
see also : GetConfidentialProductProperty
trim(
<string> )
[W/L/M]
see also : trim
lower(
<string> )
[W/L/M]
see also : lower
upper(
<string> )
[W/L/M]
see also : upper
unquote(
<string>,<quote-string> )
see also : unquote
unquote2(
see also : unquote2
stringReplace(
<string>, <oldPattern>, <newPattern> )
//since 4.11.3 [W/L/M]
see also : stringReplace
strLength(
<string> )
see also : strLength
strPos(
<string>, <sub string> )
see also : strPos
strPart(
<string>, <start pos>, <number of chars> )
see also : strPart
getValue(
<key string>, <hash string list> )
[W/L/M]
see also : getValue
getValueBySeparator(
<key string>,<separator string>,<hash string list> )
see also : getValueBySeparator
setValueByKey(
<key>, <value>, <targetlist> )
[W/L/M]
see also : prim-section.adoc#setValueByKey
getValueFromFile(
<key string>, <file name> )
//since 4.11.4.4 [W/L/M]
see also : getValueFromFile
getValueFromFileBySeparator(
<key string>,<separator string>,<file name> )
see also : getValueFromFileBySeparator
getLastExitCode : string (exitcode)
[W/L/M]
see also : getLastExitCode
Special: License Management
DemandLicenseKey(
poolId [, productId [,windowsSoftwareId]] )
set $mykey$ = DemandLicenseKey ("", "office2007")
see also : DemandLicenseKey
FreeLicense (
set $result$ = FreeLicense("", "office2007")
see also : FreeLicense
Special: Usercontext / loginscripts [W]:
GetUserSID(
<Windows Username> )
see also : GetUserSID
GetLoggedInUser
//since 4.11.1.2
see also : GetLoggedInUser
GetUsercontext
//since 4.11.1.2
GetScriptMode
possible values 'Machine','Login' //since 4.11.2.1
see also : GetUsercontext
saveVersionToProfile
- save productversion-packageversion to local profile //since 4.11.2.1
see also : saveVersionToProfile
readVersionFromProfile
: string - read productversion-packageversion from local profile //since 4.11.2.1
see also : readVersionFromProfile
scriptWasExecutedBefore
: boolean - is true if saved and running productversion-packageversion are identical //since 4.11.2.1
see also : scriptWasExecutedBefore
Other
GetHostsName (
<hostaddress> )
[W/L/M]
see also : GetHostsName
GetHostsAddr (
<hostname> )
[W/L/M]
see also : GetHostsAddr
ExtractFilePath (
<path> )
[W/L/M]
see also : ExtractFilePath
calculate(
<arithmetic string expression> )
// since 4.11.3.5 : knows: +-*/()
[W/L/M]
see also : calculate
DecStrToHexStr (
<decstring>, <hexlength> )
[W/L/M]
see also : DecStrToHexStr
HexStrToDecStr (
<hexstring> )
[W/L/M]
see also : HexStrToDecStr
base64EncodeStr(
<string> )
[W/L/M]
see also : base64EncodeStr
base64DecodeStr(
<string> )
[W/L/M]
see also : base64DecodeStr
convert2Jsonstr(
<string> )
//since 4.10.8.3
RandomStr
[W/L/M]
see also : RandomStr
RandomStrWithParameters
[W/L/M]
see also : RandomStrWithParameters
RandomIntStr(
<number str> ) : string
[W/L/M]
see also : RandomIntStr
CompareDotSeparatedStrings(
<string1>, <string2> ) : string
[W/L/M]
see also : CompareDotSeparatedStrings_str
CompareDotSeparatedNumbers(
[W/L/M]
see also : CompareDotSeparatedNumbers_str
EnvVar (
<environment variable> )
[W/L/M]
see also : EnvVar
ParamStr
[W/L/M]
see also : ParamStr
getDiffTimeSec
(Time in seconds since last marktime) //since 4.11.3 [W/L/M]
see also : getDiffTimeSec
SidToName(
<well known sid> )
//since 4.11.3: gives localized name of the sid [W]
see also : SidToName
GetMyIpByTarget(
<target ip addr> ) : string
//since 4.11.3.2 /4.11.6 [W/L/M]
GetIpByName(
<ip addr / ip name> )
//since 4.11.3.2 [W/L/M]
see also : GetIpByName
reencodestr(
<str>, <from>, <to> )
//since 4.11.4.2 [W/L/M]
see also : reencodestr
strLoadTextFile (
<filename> )
//since 4.11.4.6 [W/L/M]
see also : strLoadTextFile
strLoadTextFileWithEncoding (
<filename> , <encoding> )
see also : strLoadTextFileWithEncoding
GetShortWinPathName(<longpath string>)
//since 4.11.5.2 [W]
see also : GetShortWinPathName
stringinput(
< message str>,< boolstr confidential> ) : string
//since 4.12.1.2 [W/L/M]
see also : stringinput
which(
<command in path> ) : string
(command with path) //since 4.12.3.6 [W/L/M]
see also : which
<string> ) : string
ReadTOMLFile(
<TOMLfilePath: String> ) : String
//since 4.12.5.0 [W/L/M]
see also : ReadTOMLFile
GetTOMLAsString(
<TOMLcontents: String> ) : String
see also : GetTOMLAsString
GetTOMLTableAsString(
<TOMLcontents: String> , <table name : String> ) : String
see also : GetTOMLTableAsString
GetValueFromTOML(
<TOMLcontents: String> , <keyPath: String> , <defaultValue: String> ) : String
see also : GetValueFromTOML
ModifyTOML(
<TOMLcontents: String> , <command: String> , <keyPath: String> , <value: String> ) : String
see also : ModifyTOML
DeleteTableFromTOML(
<TOMLcontents: String> , <tablePath: String> ) : String
//since 4.12.5 [W/L/M]
see also : DeleteTableFromTOML
ConvertTOMLtoJSON(
see also : ConvertTOMLtoJSON
Deprecated
GetNtVersion
Deprecated - please use GetMsVersionInfo
[W]
IniVar (
<key> )
: (deprecated; use GetProductProperty) [W]
SubstringBefore (
(deprecated; use splitString
/ takestring
) [W/L/M]
see also : splitString
String list functions
Important
splitString (
[W/L/M]
set $list1$ = splitString ("\\server\share\dir","\")
splitStringOnWhiteSpace (
<string> )
[W/L/M]
see also : splitStringOnWhiteSpace
loadTextFile (
<file name> )
[W/L/M]
see also : loadTextFile
loadUnicodeTextFile (
<file name> )
[W]
see also : loadUnicodeTextFile
loadTextFileWithEncoding(
<file name> ,
<encoding> )
//since 4.11.5 [W/L/M]
see also : loadTextFileWithEncoding
composeString (
<string list>, <Link> )
[W/L/M]
see also : composeString
takeString (
<index>, <list> )
[W/L/M]
see also : takeString
setStringInListAtIndex(
<newstring>,<list>,<indexstr> ) : stringlist
//since 4.11.6 [W/L/M]
see also : setStringInListAtIndex
takeFirstStringContaining(
<list>,<search string> )
[W/L/M]
see also : takeFirstStringContaining
getOutStreamFromSection (
<dos section name> )
[W/L/M]
set $list$= getOutStreamFromSection ('ShellScript_try')
see also : getOutStreamFromSection
shellCall (
<command string> ) : stringlist (output)
set $list$= shellCall('net start')
see also : shellCall_list
getReturnListFromSection (
<xml section name> )
[W/L/M]
see also : getReturnListFromSection
getListContaining(
[W/L/M]
see also : getListContaining
getListContainingList(
<list1>,<list2> )
//since 4.11.3.7 [W/L/M]
see also : getListContainingList
count (
<list> )
[W/L/M]
see also : count
emptylist (
<list> )
see also : emptylist
for %
<identifier> % in
<list> do
<one statement | sub section> [W/L/M]
for %s% in $list1$ do sub_test_string
see also : forInDo
GetProcessList
//since 4.11.1.2; gives list of exename;pid;dom/user [W/L/M]
see also : GetProcessList
getProductPropertyList(
<propname>,<default value> )
see also : getProductPropertyList
getRegistryKeyList32(
<regkey> )
//since 4.11.3 [W]
see also : getRegistryKeyList32
getRegistryKeyList64(
<regkey> )
//since 4.11.3 [W]
see also : getRegistryKeyList64
getRegistryKeyListSysnative(
<regkey> )
//since 4.11.3 [W]
see also : getRegistryKeyListSysnative
getRegistryKeyList(
<regkey>, <access str> )
//since 4.12.5.0 [W]
getRegistryVarList32(
<regkey> )
//since 4.11.3 [W]
see also : getRegistryVarList32
getRegistryVarList64(
<regkey> )
//since 4.11.3 [W]
see also : getRegistryVarList64
getRegistryVarListSysnative(
<regkey> )
//since 4.11.3 [W]
see also : getRegistryVarListSysnative
getRegistryVarList(
getProfilesDirList
see also : getProfilesDirList
listFiles (
<Path>, <Searchmask> , <SearchSubDirectories>[, <Redirection>]) : stringlist
//since 4.12.3 [W/L/M]
Set $Filelist$ = listFiles("C:\windows\system32","*.ico;*.dll","False","64bit")
see also : listFiles
Infomaps
GetLocaleInfoMap
[W]
see also : GetLocaleInfoMap
GetMSVersionMap
[W]
see also : GetMSVersionMap
getLinuxVersionMap
//since 4.11.4 [L]
keys are (example):
Distributor ID=Ubuntu
Description=Ubuntu 12.04.2 LTS
Release=12.04
Codename=precise
kernel name=Linux
node name=detlefvm05
kernel release=3.2.0-40-generic-pae
kernel version=#64-Ubuntu SMP Mon Mar 25 21:44:41 UTC 2013
machine=i686
processor=athlon
hardware platform=i386
operating system=GNU/Linux
see also : getLinuxVersionMap
getFileInfoMap(
<file name> )
[W]
see also : getFileInfoMap
getProductMap
// since 4.11.2.4 [W/L/M]
keys are: id, name, description, advice, productversion, packageversion, priority, installationstate, lastactionrequest, lastactionresult, installedversion, installedpackage, installedmodificationtime,actionrequest
see also : getProductMap
getRegistryVarMap32(
<regkey> )
//since 4.11.3 [W]
see also : getRegistryVarMap32
getRegistryVarMap64(
<regkey> )
//since 4.11.3 [W]
see also : getRegistryVarMap64
getRegistryVarMapSysnative(
<regkey> )
//since 4.11.3 [W]
see also : getRegistryVarMapSysnative
getRegistryVarMap(
getHWBiosInfoMap
//since 4.11.4 [W/L/M]
see also : getHWBiosInfoMap
editmap(
<strlist> ) : stringlist
see also : editmap
Other
createStringList (
<string0>, <string1> ,… )
[W/L/M]
set $list1$ = createStringList ('a','b')
see also : createStringList
reverse (
<list> )
[W/L/M]
see also : reverse
getSectionNames(
<ini-file> )
[W/L/M]
see also : getSectionNames
retrieveSection (
<section name> )
[W/L/M]
see also : retrieveSection
getSubList (
<start index> : <end index>, <list> )
[W/L/M]
see also : getSubList
getSubListByMatch (
<search string>, <target list> )
:stringlist //since 4.12.0.14 [W/L/M]
see also : getSubListByMatch_sl
getSubListByMatch (
<search list>, <target list> )
see also : getSubListByMatch_ll
getSubListByContaining (
see also : getSubListByContaining_sl
see also : getSubListByContaining_ll
getSubListByKey (
see also : getSubListByKey_sl
getSubListByKey (
see also : getSubListByKey_ll
getKeyList (
<list> )
see also : getKeyList
addtolist(
<list>,<string> )
//since 4.10.8 [W/L/M]
see also : addtolist
addListToList(
<dest list>,<src list> )
see also : addListToList
reencodestrlist(
<list>, <from>, <to> )
see also : reencodestrlist
removeFromListByContaining(
<search string> ,
<target list> ) : stringlist
//since 4.11.5.1 [W/L/M]
see also : removeFromListByContaining_str
<search list> ,
see also : removeFromListByContaining_list
removeFromListByMatch(
<searchstring>,<target list> ) : stringlist
see also : removeFromListByMatch
LoadTOMLFile(
<TOMLfilePath: String> ) : StringList
see also : LoadTOMLFile
GetTOMLAsStringList(
<TOMLcontents: String> ) : StringList
see also : GetTOMLAsStringList
GetTOMLKeys(
see also : GetTOMLKeys
GetTOMLTableNames(
see also : GetTOMLTableNames
GetTOMLTable(
<TOMLcontents: String> , <table name : String> ) : StringList
Boolean operators and functions
see also : Boolean Expressions
<string1> =
<string2> [W/L/M]
<bool1> AND
<bool2> [W/L/M]
<bool1> OR
<bool2> [W/L/M]
NOT
(<bool3>) [W/L/M]
FileExists (
<file name> )
[W/L/M]
see also : FileExists
FileExists32 (
<file name> )
[W]
FileExists64 (
<file name> )
[W]
FileExistsSysNative (
<file name> )
[W]
DirectoryExists (
<folder path> )
//since 4.12.1 [W/L/M]
'sysnative' is the default for <access str>. Otherwise, it can be '32bit', '64bit' or 'sysnative'
see also : DirectoryExists
FileOrFolderExists (
<file or folder path> )
[W/L/M]
see also : FileOrFolderExists
fileIsSymlink (
<file name> )
// since 4.12.4.21 [W/L/M]
see also : fileIsSymlink
LineExistsIn (
<string>, <file name> )
[W/L/M]
see also : LineExistsIn
LineBeginning_ExistsIn (
[W/L/M]
see also : LineBeginning_ExistsIn
LineContaining_ExistsIn(
//since 4.11.4.10: true: if a in <file name> contains <string> [W/L/M]
see also : LineContaining_ExistsIn
XMLAddNamespace(
<XMLfilename>, <XMLelementname>, <XMLnamespace> )
[W]
see also : XMLAddNamespace
XMLRemoveNamespace(
[W]
see also : XMLRemoveNamespace
HasMinimumSpace (
<drive letter>, <capacity> )
[W]
see also : HasMinimumSpace
Example:
if not (HasMinimumSpace ("%SYSTEMDRIVE%", "500 MB"))
LogError "Required free space of 500 MB not available on %SYSTEMDRIVE%"
isFatalError
opsiLicenseManagementEnabled
[W/L/M]
see also : opsiLicenseManagementEnabled
runningAsAdmin
//since 4.11.1.1 [W/L/M]
see also : runningAsAdmin
isLoginScript
//since 4.11.2.1 [W]
see also : isLoginScript
contains(
<str>, <substr> )
//since 4.11.3: true if <substr> in <str> [W/L/M]
see also : contains
isNumber(
<str> )
//since 4.11.3: true if <str> represents an integer [W/L/M]
see also : isNumber
runningOnUefi
//since 4.11.4.3: true: if the running OS was booted in UEFI mode [W]
see also : runningOnUefi
runningInPE
//since 4.12.0.13: true: if the running OS is a Windows PE [W/L/M]
see also : runningInPE
runningInWAnMode
//since 4.12.4.16: true: if opsiserver = localhost [W/L/M]
see also : runningInWAnMode
isDriveReady(
<drive letter> )
//since 4.11.4.4: true: if the drive can be accessed [W]
see also : isDriveReady
runningWithGui
//since 4.12.3.6: true: if the running OS has a GUI (at Win+Mac always true)[M/L/W]
see also : runningWithGui
saveTextFile(
<list>, < filename> )
//since 4.11.4.4: true: if list is succesfully written to file [W/L/M]
see also : saveTextFile
saveTextFileWithEncoding(
<list>, < filename>, <encoding> )
//since 4.11.6.4: true: if list is succesfully written to file [W/L/M]
see also : saveTextFileWithEncoding
saveUnicodeTextFile(
//since 4.12.4.13: true: if list is succesfully written to unicode file [W/L/M]
see also : saveUnicodeTextFile
<str1>,<relation str>,<str2> )
//since 4.11.5.2: [W/L/M]
see also : CompareDotSeparatedNumbers_bool
see also : CompareDotSeparatedStrings_bool
RegKeyExists(
<regkey>[,<access str>])
see also : RegKeyExists
RegVarExists(
<regkey>, <var str>[,<access str>])
see also : RegVarExists
isPingReachable(
<host> )
see also : isPingReachable
isValidFQDN(
<domain name> )
//since 4.12.4.4 [W/L/M]
see also : isValidFQDN
fileHasBom (
<file name> )
see also : fileHasBom
SaveToTOMLFile(
<TOMLcontents: String> , <TOML file Path: String> )
see also : SaveToTOMLFile
ConvertTOMLfileToJSONfile(
<TOMLfilePath: String> , <JSONfilePath: String> )
see also : ConvertTOMLfileToJSONfile
Misc functions
Killtask
<process name> [W/L/M]
see also : Killtask
requiredOpsiscriptVersion
<relation operator> <version> //since 4.12.3.6 [W/L/M]
requiredOpsiscriptVersion >= "4.12.3.6"
see also : requiredOpsiscriptVersion
requiredWinstVersion
<relation operator> <version> [W/L/M]
outdatet - use requiredOpsiscriptVersion
UpdateEnvironment
//since 4.11.5 [W]:
Subsequent calls of winbatch
with the parameter /RunElevated
will see the changed Environment (NT6 only).
see also : UpdateEnvironment
Flow control
'if - elseif - else - endif' [W/L/M] see also : Syntax und Bedeutung der primären Sektionen eines opsi-script Skriptes [W/L/M]]
Syntax:
if
<condition>
;statement(s)
[elseif
<condition>
;statement(s)]
[else
;statement(s)]
elseif
//since 4.12.4.37
Example:
Set $NTVer$ = GetMsVersionInfo
if ( $NTVer$ >= "6" )
sub_install_win7
else
if ( $NTVer$ = "5.1" )
sub_install_winXP
else
'for - to - do' Statement //since 4.11.5 [W/L/M] see also : ForToDo
for
%<temporary string variable>% =
<start string> to
<end string> do
<one statement>
Example:
for %s% = "1" to "5" do sub_iteration_test
'Switch / Case' Statement //since 4.11.5 [W/L/M]
ifdef::manual[see also : SwitchCase]
Can not be nested.
see also : IfElseEndif
Syntax:
Switch <string expression> Case <string const> <statement(s)> EndCase [DefaultCase <statement(s)> EndCase] EndSwitch
Example:
set $ConstTest$ = "5"
Switch $ConstTest$
Case "1"
set $CompValue$ = "1"
EndCase
Case "2"
set $CompValue$ = "2"
EndCase
DefaultCase
set $CompValue$ = "notexisting"
EndCase
EndSwitch
isFatalError
[W/L/M]
see also : isFatalError
isFatalError
<string> //since 4.11.3.2 [W/L/M]
isSuccess
see also : isSuccess
isSuspended
see also : isSuspended
noUpdateScript
see also : noUpdateScript
ExitWindows /Reboot
[W/L/M]
see also : Reboot
ExitWindows /ImmediateReboot
[W/L/M]
see also : ImmediateReboot
ExitWindows /ImmediateLogout
[W]
see also : ImmediateLogout
ExitWindows /ShutdownWanted
[W]
see also : ShutdownWanted
ExitWindows /RebootWanted
(deprecated, acts like /Reboot) [W]
see also : Reboot
sleepSeconds
<Integer> or <string> : noresult [W/L/M]
see also : sleepSeconds
ChangeDirectory
<directory> //since 4.11.2.6 [W/L/M]
see also : ChangeDirectory
Secondary Sections
Winbatch [W/L/M]
see also : WinBatch-Sections [W/L/M]
Function: execute programs via operating system API
[WinBatch
<identifier> ]
Modifier:
/LetThemGo
/WaitForProcessEnding
"<program.exe>"
/TimeOutSeconds
<seconds>
/WaitForWindowAppearing
<window title> ('does not work with 64 Bit programs') [W]
/WaitForWindowVanish
/RunElevated
// since 4.11.3: only at >= NT6 ; no network access [W]
/RunAsLoggedOnUser
// since 4.11.3.5 ; works only inside 'userLoginScripts' [W]
/32Bit
//since 4.11.3.5 [W]
/64Bit
/SysNative
ShellScript (deprecated: DosBatch, DosInAnIcon, ShellBatch, ShellInAnIcon) //since 4.12.10.0 [W/L/M]
see also : ShellScript section
see also : ShellScript Sections
Function: Execute section via cmd.exe [W] or bash [L/M]
[ShellScript<identifier> ]
<optional parameters> <winst <modifier>>
Modifier: //since 4.11.1.1
/32Bit [W]
/64Bit [W]
/SysNative [W]
/showoutput [W/L/M] // since 4.11.4.7
/WaitForProcessEnding "<program.exe>" // since 4.12.4 [W/L/M]
/TimeOutSeconds <seconds> // since 4.12.4 [W/L/M]
/LetThemGo //since 4.12.10.0
/RunElevated // since 4.12.4: only at >= NT6 ; no network access [W]
/RunAsLoggedOnUser // since 4.12.4.31 ; works only inside 'userLoginScripts' [W]
The modifiers has to be seperated by 'winst' from the parameters.
ShellScript_do_64bit_stuff winst /64Bit
ExecWith [W/L/M]
see also : ExecWith Sections
Function: Execute section via any interpreter
[ExecWith
<identifier> ]
<path to interpreter>
Modifier:
/LetThemGo
/EscapeStrings
/32Bit
/64Bit
/SysNative
The modifiers has to be seperated by 'winst' from the parameters. The following example call the 64Bit version of the powershell.exe.
ExecWith_do_64bit_stuff "%System%\WindowsPowerShell\v1.0\powershell.exe" winst /64Bit
Commands: see manual
Files [W/L/M]
see also : Files
Function: File Operations
[Files
<identifier> ]
Modifier [W]:
/AllNTUserProfiles
/AllNTUserSendTo
[W]
/32Bit
//since 4.10.8 [W]
/64Bit
//since 4.10.8 [W]
/SysNative
//since 4.10.8 [W]
Commands:
checkTargetPath =
<destination directory> [W/L/M]
copy
[Options] <source file(s)> <destination directory> [W/L/M]
some options:
-s
recursive [W/L/M]
-e
empty Subdirectories
-V
version control against targetdir [W]
-v
version control against targetdir, %systemroot% and %system% (do not use it) [W]
-c
continue without reboot even if it is needed [W]
-d
date check [W]
-u
update [W]
-x
extract [W]
-w
weak (do not overwrite protected files) [W]
-n
no overwrite [W]
-r
copy read only attribute [W]
-h
follow symlinks [L] //since 4.11.6.14
delete
[Options] <path[/mask]] // [W/L/M]
options:
-s
recursive
-f
force
r
-del on reboot
c
continue with out reboot
d [n]
date
Example (do not forget the trailing Backslash):
delete -sf c:\delete_this_dir\
del
[Options] <path[/mask]] //since 4.11.2.1 [W/L/M]
Works like delete
but on
del -s -f c:\not-exists
if c:\not-exists not exists it do not search complete c:\ for not-exits
Example (you may forget the trailing Backslash):
del -sf c:\delete_this_dir
chmod
<mode> <path> //since 4.11.4.1 [L]
hardlink
<existing file> <new file> // since 4.11.5 [W/L/M]
symlink
At Windows symlink
is only available at NT6 and up.
rename
<old filename> <new filename> // since 4.11.5 [W/L/M]
move
zipfile
<source dir> <zip file> // since 4.12.1 [W/L/M]
unzipfile
<zip file> <target dir> [<encoding>] // since 4.12.1 [W/L/M]
Registry [W]
see also : Registry
Function: edit Registry
Standard method call:
[Registry
<identifier> ]
works with the specified section.
Alternative method call:
Registry loadUnicodeTextFile(
<.reg file> ) /regedit
import the specified <.reg file>.
Alternative method call (deprecated):
<.addreg file> ) /addreg
import the specified <.addreg file>.
Modifier:
/AllNTUserDats
/32Bit
//since 4.10.8
/64Bit
//since 4.10.8
/SysNative
//since 4.10.8
Commands:
OpenKey
<Key>
openkey [HKLM\Software\opsi.org]
Set
<varname> =
<registry type>:<value>
Add
<varname> =
Examples for registry types:
set "var1" = "my string"
set "var2" = REG_SZ:"my string"
set "var3" = REG_EXPAND_SZ:"%ProgramFiles%"
set "var4" = REG_DWORD:123 ; Decimal
set "var5" = REG_DWORD:0x7b ; Hexadecimal
; REG_QWORD is supported since 4.12.6
set "var6" = REG_QWORD:59049772908 ; Decimal
set "var7" = REG_QWORD:0xDBFA4076C ; Hexadecimal
set "var8" = REG_BINARY:00 01 02 0F 10
set "var9" = REG_MULTI_SZ:"A|BC|de"
Supp
<varname> <list char> <supplement>
supp "Path" ; "C:\utils; %JAVABIN%"
GetMultiSZFromFile
<varname> <file name>
SaveValueToFile
DeleteVar
<varname>
DeleteKey
<registry key> (does since 4.11.2.1 also work with /AllNTUserDats)
Patches [W/L/M]
see also : Patches
Function: edit Ini-files
[Patches
<identifier> ]
<file name>
Modifier:
/AllNTUserProfiles
//since 4.11.3 [W]
Commands:
add [
<section name> ]
<variable1> =
<value1>
set [
<section name> ]
<variable1> =
<value1>
addnew [
<section name> ]
<variable1> =
<value1>
change [
<section name> ]
<variable1> =
<value1>
del [
<section name> ]
<variable1> =
<value1>
del [
<section name> ]
<variable1>
delsec [
<section name> ]
replace
<variable1> =
<value1> <variable2> =
<value2>
PatchTextFile [W/L/M]
see also : PatchTextFile
Function: edit text files
[PatchTextFile
<identifier> ]
<file name>
Modifier:
/AllNTUserProfiles
//since 4.11.3.4 [W]
/encoding
<encoding> //since 4.12.4.17 [W/L/M]
Commands:
Set_Mozilla_Pref (
<preference type>, <preference key>, <preference value> )
'preference type' takes any value.
Some examples for preference types: pref
, user_pref
, lock_pref
or lockPref
AddStringListElement_To_Mozilla_Pref (
<preference type>, <preference key>, <add value> )
Set_Netscape_User_Pref (
<key>, <value> )
('deprecated')
AddstringListElement_To_Netscape_User_Pref
('deprecated')
FindLine
<search string>
FindLine_StartingWith
<search string>
FindLine_Containing
<search string>
GoToTop
AdvanceLine
[<number of lines>]
GoToBottom
DeleteTheLine
AddLine_
<line> or Add_Line_
<line>
InsertLine
<line> or Insert_Line_
<line>
AppendLine
<line> or Append_Line
<line>
Append_File
<file name>
Subtract_File
<file name>
SaveToFile
<file name>
Sorted
setKeyValueSeparator
<separator char> //since 4.11.4.4 [W/L/M]
setValueByKey
<keystr> <valuestr> //since 4.11.4.4 [W/L/M]
searchAndReplace
<searchstr> <replacestr> //since 4.11.4.6 [W/L/M]
LinkFolder [W/L/M]
see also : LinkFolder
Function: Startmenue + Desktop Icons
[LinkFolder
<identifier> ]
Commands:
set_basefolder
<system folder>
set_subfolder
<folder path> (at Linux set always "")
set_link name: <link name> target: <path and name of the program> parameters: [command line arguments] working_dir: [working directory] icon_file: [path and name of icon file, default=target] icon_index: [number of icon in icon file, default=0] [W] shortcut: [keyboard shortcut for calling the target] [W] link_categories: [list of categories] [L] end_link
delete_element
<link name>
delete_subfolder
<folder path> [W]
The predefined virtual system folders which can be used are at Windows:
desktop, sendto, startmenu, startup, programs, desktopdirectory
common_startmenu, common_programs, common_startup, common_desktopdirectory
and at Linux:
common_programs
,common_startup
,desktop
, startup
Predefined link_categories
for Linux:
AudioVideo
, Audio
, Video
, Development
, Education
, Game
, Graphics
, Network
, Office
, Settings
, System
, Utility
Examples
set_basefolder common_desktopdirectory
set_subfolder ""
set_link
target: "%ProgramFiles32Dir%\opsi.org\opsi-client-agent\opsi-winst\winst32.exe"
end_link
[LinkFolder_configed_lin]
set_subfolder ""
set_link
target: java
parameters: $parameter$
icon_file: "$InstallDir$/opsi.png"
link_categories: System;Utility;
end_link
The predefined virtual system folders:
are pointing to the folders of the user that the script is running.
If you use it in a userLoginScript with the opsi 'User Profile Management' extension these virtual folders point to the folder of the user that just had logged in.
'shortcut' defaults to empty. // since 4.11.6.7
shortcut
may be a combination of ['shift','alt','ctrl'] (not case sensitiv) divided by ' ', '-','+' an a 'Key' or a 'Virtual Key Code'.
The 'Key' is a letter ('A' - 'Z') or a numeral ('0' - '9'). All other Keys must be given by there 'Virtual Key Code' identifier.
OpsiServiceCall [W/L/M]
see also : OpsiServiceCall
Function: opsi-Service access
[OpsiServiceCall
<identifier> ]
PatchHosts [W/L/M]
see also : PatchHosts
Function: hosts-files bearbeiten
[PatchHosts
<identifier> ]
Commands:
setaddr
<hostname> <IPaddress>
setname
<IPaddress> <hostname>
setalias
<hostname> <alias>
setalias
<IPadresse> <alias>
delalias
<hostname> <alias>
delalias
<IPaddress> <alias>
delhost
<hostname>
delhost
<ipadresse>
setComment
<ident> <comment>
XML2 Sections [W/L/M]
see also : XML2 Sections
Function: edit XML files
since 4.12.1.0
[XML2
<identifier> ]
Commands:
strictMode =
(true/false) ; Default: false -
openNode
<xml2 path>
Open the given path as actual node. If the path does not exist, it will be created. -
SetAttribute
<attr name> <attr value>
At the actual node set <attr value> as value of <attr name>. If <attr name> does not exist, it will be created. -
AddAttribute
If the attribute <attr name> does not exist at the actual node, it will be created with <attr value> as value. If <attr name> already exists, nothing will be changed. -
DeleteAttribute
<attr name>
If the attribute <attr name> exists at the actual node, it will be deleted. -
addNewNode
<node name>
Create at the actual node a new sub node <node name> and make this new node to the actual node. -
setNodeText
<string> -
DeleteNode
<xml2 path> -
gotoParentNode
Make the parent node to the actual node. -
rootNodeOnCreate
= <node name> // since 4.12.4.27
If the file does not exist, it will be created with <node name> as root node name. -
setNodePair
<keyNodeName> <keyNodeTextContent> <valueNodeName> <valueNodeTextContent> // since 4.12.4.28
Creates a <dict> entry like it is used in the Apple info.plist files.
Some notes on the command parameters:
<xml2 path>
strictMode =false
A line of xml node names without any attributes seprated by//
Example:node_level-1_number-1 // node_level-2_B color="green"
<xml2 path>
strictMode =true
A line of xml node names with all existing attributes seprated by//
Example:node_level-1_number-1 // node_level-2_B color="green" count="65"
see also : XML related functions (XML2) [W/L/M]:
see also : XML2 Functions
XMLPatch [W]
see also : XMLPatch
Deprecated: please use xml2 sections: XML2 Sections [W/L/M]
and xml2 functions: XML related functions (XML2) [W/L/M]:
[XMLPatch
<identifier> ]
ExecPython [W/L/M]
see also : ExecPython
Function: Execute section via python interpreter
[ExecPython
<identifier> ]
LdapSearch [WLM]
see also : LdapSearch
Function: read from LDAP
[LdapSearch
<identifier> ]
By Topic
Compare related functions [W/L/M]
[W/L/M]
<str1>,<relation str>,<str2> ) : bool
[W/L/M]
boolToString(
<boolean expression> )
: bool string (true/false) // since 4.12.0.0 [W/L/M]
see also : boolToString
stringToBool(
<string expression: true/false> )
: boolean // since 4.12.0.0 [W/L/M]
see also : stringToBool
Crypt / Hash related functions [W/L/M]
DecStrToHexStr (
<decstring>, <hexlength> ) : string
[W/L/M]
HexStrToDecStr (
<hexstring> ) : string
[W/L/M]
base64EncodeStr(
<string> ) : string
[W/L/M]
base64DecodeStr(
<string> ) : string
[W/L/M]
RandomStr : string
[W/L/M]
RandomIntStr(
[W/L/M]
encryptStringBlow(
<keystring>,<datastring> ) : string
[W/L/M]
see also : encryptStringBlow
decryptStringBlow(
[W/L/M]
see also : decryptStringBlow
md5sumFromFile(
<path to file> ) : string
[W/L/M]
see also : md5sumFromFile
hashFromFile(
<FileName>, <Hashing Algorithm> ) : string
[W/L/M] //since 4.12.5
see also : hashFromFile
isCertInstalledInSystem(
<label> ) : boolstring
[W/L/M] //since 4.12.4.37
see also : isCertInstalledInSystem
importCertToSystem(
<filename> ) : noresult
see also : importCertToSystem
removeCertFromSystem(
<label> ) : noresult
see also : removeCertFromSystem
listCertificatesFromSystem : stringlist
see also : listCertificatesFromSystem
Defined Functions and Libraries [W/L/M]
since 4.12.0.0
Definition
DefFunc <func name>([calltype parameter ptype][,[calltype parameter ptype]]) : ftype <function body> endfunc
Where:
DefFunc
is the keyword used to start defining a local function. -
'<func name>' is the freely choosen name of the function.
'calltype' is the call type of the parameter [
val
|ref
].val
='Call by Value',ref
='Call by Reference'. Default:val
'parameter' is the freely selected name of the call parameter which is available as a local variable within the function under the aforementioned name.
'ptype' is the type of data of the parameter and either
string
orstringlist
'ftype' is the type of data of the function and either
string
,stringlist
orvoid
.void
declares that no result is returned. -
'<function body>' is the body of the function which must conform to the opsi-script syntax.
endfunc
is the keyword used to end defining a local function.
see also : localfunctions
importLib
<string expr> ; import library // since 4.12.0.0
<string expr> : <file name>[.<file extension>][::
<function name>]
If no '.<file extension>' is given .opsiscript
is used as default.
If no '::<function name>' is given, all function from the given file will be imported.
<file name> is:
A complete path to an existing file. [W/L/M]
An existing file in
%ScriptPath%
[W/L/M] -
A file in
%opsiScriptHelperPath%\lib
[W]
Is equivalent to: '%ProgramFiles32Dir%\opsi.org\opsiScriptHelper\lib' -
An existing file in
%ScriptPath%/../lib
[W/L/M] -
An existing file in
%WinstDir%\lib
[W] or/usr/share/opsi-script/lib
[L]
The tests for the location of the <file name> are done in the order above. 'opsi-script' uses the first file it finds that has a matching name.
see also : Import of libraries of functions
Encoding related functions [W/L/M]
encoding=
see also : encoding
GetLocaleInfoMap : stringlist
[W]
reencodestr(
<str>, <from>, <to> ) : string
reencodestrlist(
<list>, <from>, <to> ) : stringlist
fileHasBom (
<file name> ) : boolean
<file name> ) : stringlist
[W/L/M]
<file name> ,
<encoding> ) : stringlist
<filename> , <encoding> ) : string
<list>, < filename> ,
<encoding> ) : bool
includelog
<file name> <tail size> [<encoding>] : noresult
see also : 'opsi-script' encoding
Error / Warning related functions [W/L/M]
ExitOnError
ScriptErrorMessages
= <boolean value> // (default=true)
LogError
= <const string>
see also : LogError
LogWarning
= <const string>
isFatalError
[W/L/M]
isFatalError
markErrorNumber
see also : markErrorNumber
errorsOccurredSinceMark
<relation> <integer> : boolean
see also : errorsOccurredSinceMark
markErrorNumber
comment "log error and thereby increase the error counter"
if errorsOccurredSinceMark > 0
comment "There was an error ..."
[W/L/M]
shellCall (
<command string> ) : string (exitcode)
//since 4.11.6.1 [W/L/M]
see also : shellCall_str
processCall(
<string> ) : string (exitcode)
see also : processCall
getLastServiceErrorClass
: string
see also : getLastServiceErrorClass
getLastServiceErrorMessage
: string
see also : getLastServiceErrorMessage
File related functions [W/L/M]
strLoadTextFile (
[W/L/M]
loadTextFile (
[W/L/M]
[W]
<file name> ,
fileHasBom (
FileExists (
[W/L/M]
FileExists32 (
[W]
FileExists64 (
[W]
[W]
DirectoryExists
(<folder path> [,<access str>]) : boolean //since 4.12.1 [W/L/M]
FileOrFolderExists
(<file or folder path> [,<access str>]) : boolean [W/L/M]
fileIsSymlink (
resolveSymlink (
see also : resolveSymlink
listFiles (
<Path>, <Searchmask> , <SearchSubDirectories>, <[Redirection]> ) : stringlist
forcePathDelims (
<path string> ) : string
see also : forcePathDelims
LineExistsIn (
<string>, <file name> ) : bool
[W/L/M]
[W/L/M]
//since 4.11.4.10 [W/L/M]
saveTextFile(
<list>, < filename> ) : bool
<encoding> ) : bool
//since 4.11.6.4 [W/L/M]
getFileInfoMap(
[W]
getFileInfoMap32(
//since 4.11.6.6 [W]
getFileInfoMap64(
getFileInfoMapSysnative(
ExtractFilePath (
<path> ) : string
[W/L/M]
ExtractFileExtension (
<path> ) : string
[W/L/M] //since 4.12.1
see also : ExtractFileExtension
ExtractFileName (
<path> ) : string
see also : ExtractFileName
see also: Files [W/L/M]
see also: PatchTextFile [W/L/M]
Ini file related functions [W/L/M]
<file path>, <section>, <key>, <default value>, OPTIONAL <encoding> ) : string
[W/L/M]
getSectionNames(
<ini-file> ) : stringlist
[W/L/M]
GetSectionFromInifile(
[W/L/M]
see also : GetSectionFromInifile
getValue(
<key string>, <hash string list> ) : string
[W/L/M]
see also : getValue
<key string>,<separator string>,<hash string list> ) : string
setValueByKey(
: stringlist [W/L/M]
getValueFromFile(
<key string>, <file name> ) : string
<key string>,<separator string>,<file name> ) : string
see also: Patches [W/L/M]
Interaction [W/L/M]
Pause
<string> or Pause
= <const string>
see also : Pause
Stop
<string> or stop
= <const string>
see also : Stop
setActionProgress
<string> //since 4.11.3 [W/L/M]
see also : setActionProgress
Message
<string> or Message
= <const string>
see also : Message
ShowMessageFile
<string>
ShowBitMap
stringinput(
editmap(
< strlist> ) : stringlist
see also : editmap
License Management related functions [W/L/M]
DemandLicenseKey(
poolId [, productId [,windowsSoftwareId]] ) : string
FreeLicense (
poolId [, productId [,windowsSoftwareId]]) : string
: string
: string
: bool
Linux specific functions [W/L/M]
GetOS : string
// 'Linux' or 'Windows_NT' or 'macos' [W/L/M]
see also : GetOS
getLinuxDistroType : string
) [L]
getLinuxVersionMap : stringlist
//since 4.11.4 [L]
chmod
in Files sections [L/M]
see also : Commands
waitForPackageLock(
<wait_seconds>,<abort_on_timeout> ) : bool
// since 4.11.6.1 [L]
see also : waitForPackageLock
importlib "uib_lin_install"
cleanupPackageSystem : void
//since 4.13.4 [L]
see also : cleanupPackageSystem
installupdates : string
//since 4.13.4 [L]
see also : installupdates
debinstall($packagelist$ : stringlist) : string
//since 4.13.4 [L]
see also : debinstall
redinstall($packagelist$ : stringlist) : string
//since 4.13.4 [L]
see also : redinstall
suseinstall($packagelist$ : stringlist) : string
//since 4.13.4 [L]
see also : suseinstall
ucsinstall($packagelist$ : stringlist) : string
//since 4.13.4 [L]
see also : ucsinstall
genericLinInstall($packagelist$ : stringlist) : string
see also : genericLinInstall
linuxInstallOneOf($packagelist$ : stringlist) : string
isOneInstalled($packagelist$ : stringlist) : string
see also : linuxInstallOneOf
linuxInstallOneFile($packagefile$ : string) : string
see also : linuxInstallOneFile
linuxRemoveOnePackage($packagename$ : string) : string
see also : linuxRemoveOnePackage
linuxRemoveOneOf($packagelist$ : stringlist) : string
see also : linuxRemoveOneOf
Logging related functions [W/L/M]
SetLogLevel
SetLogLevel = 7
SetLogLevel = "7"
see also : SetLogLevel see also : cli-params.adoc#opsi-script-configs_default_loglevel see also : cli-params.adoc#opsi-script-configs_force_min_loglevel
Message
<string> or Message
= <const string>
see also : Message
comment
<string> or comment
= <const string>
see also : comment
LogError
= <const string>
LogWarning
= <const string>
see also : LogError
includelog
includelog
SetConfidential
see also : setConfidential
asConfidential(
asConfidential(
opsi-configs
opsi-script.global.debug_prog
: boolean ; if false: only Warnings and Errors from program logging; default: false
opsi-script.global.debug_lib
: boolean ; if false: only Warnings and Errors from library logging; default: false
opsi-script.global.default_loglevel
: intstr ; set the default log level; default: '6'
opsi-script.global.force_min_loglevel
: intstr ; set the minimal loglevel; default: '0'
opsi-script.global.ScriptErrorMessages
: boolean ; overwrites the opsi-script internal default; default: false
opsi-script.global.AutoActivityDisplay
: boolean ; overwrites the opsi-script internal default; default: true
opsi-script.global.SupressSystemEncodingWarning
: boolean ; suppress some encoding warnings; default: false
see also : SupressSystemEncodingWarning
opsi-script.global.ReverseProductOrderByUninstall
: boolean ; product list is reordered for uninstall; default: false
see also : ReverseProductOrderByUninstall
opsi-script.global.log_rotation_count
: boolean ; number of opsi-script.log backups; default: 8
see also : log_rotation_count
opsi-script.global.writeProductLogFile
: boolean ; logs for every single opsi product; default: false
see also : writeProductLogFile
macOS specific functions [W/L/M]
GetOS : string
see also : GetOS
getMacosVersionInfo : string
//macOS Version Information //since 4.12.1.0 [M]
see also : getMacosVersionInfo
getMacosVersionMap : stringlist
//macOS Version map //since 4.12.1.0 [M]
see also : getMacosVersionMap
GetSystemType : string
getOSArchitecture
importlib "uib_macosinstalllib"
install_macos_app($myapp$ : string) : string
[M]
see also : xref:libraries.adoc#install_macos_app>>
install_macos_pkg($mypkg$ : string) : string
[M]
see also : xref:libraries.adoc#install_macos_pkg>>
install_macos_dmg($mydmg$ : string) : string
[M]
see also : xref:libraries.adoc#install_macos_dmg>>
install_macos_zip($myzip$ : string) : string
[M]
see also : xref:libraries.adoc#install_macos_zip>>
install_macos_generic($myfile$ : string) : string
[M]
see also : install_macos_generic
Network related functions [W/L/M]
GetHostsName (
<hostaddress> ) : string
[W/L/M]
GetHostsAddr (
<hostname> ) : string
[W/L/M]
GetMyIpByTarget(
GetIpByName(
<ip addr / ip name> ) : string
isValidIP4 (<ip4adr>) : boolean
//since 4.12.1
see also : isValidIP4
isValidIP4Network (<ip4adr>, <netmask>) : boolean
//since 4.12.1
see also : isValidIP4Network
isValidIP4Host (<ip4adr>, <netmask>) : boolean
//since 4.12.1
see also : isValidIP4Host
getIP4NetworkByAdrAndMask (<ip4adr>, <netmask>) : string
//since 4.12.1
see also : getIP4NetworkByAdrAndMask
getDefaultNetmaskByIP4adr (<ip4adr>) : string
//since 4.12.1
see also : getDefaultNetmaskByIP4adr
parseUrl(<url string>) : stringlist
//since 4.12.1
see also : parseUrl
createUrl(<urlcomponents list>) : string
//since 4.12.1
see also : createUrl
isPingReachable(<host>) : boolean
//since 4.12.3.6
isValidFQDN(<domain name>) : boolean
cidrToNetmask (<string>) : string
//since 4.12.4.37
see also : prim-section.adoc#cidrToNetmask
netmaskToCidr (<string>) : string
//since 4.12.4.37
see also : prim-section.adoc#netmaskToCidr
see also : prim-section.adoc#sCertInstalledInSystem
importCertToSystem(
see also : prim-section.adoc#importCertToSystem
see also : prim-section.adoc#removeCertFromSystem
listCertificatesFromSystem(
<label> ) : stringlist
see also : prim-section.adoc#listCertificatesFromSystem
Number related functions [W/L/M]
isNumber(
<str> ) : bool
see also : isNumber
[W/L/M]
calculate(
<arithmetic string expression> ) : string (number)
// since 4.11.3.5 [W/L/M]
knows: +-*/()
DecStrToHexStr (
[W/L/M]
HexStrToDecStr (
[W/L/M]
RandomIntStr(
[W/L/M]
Operating System related functions [W/L/M]
GetOS : string
see also : GetOS
GetMsVersionInfo : string
GetMSVersionMap : stringlist
[W]
) [L]
//since 4.11.4 [L]
getOSArchitecture
getListFromWMI(
<wmi namespace str>,<wmi class str>,<property list>,<condition str> ) : stringlist
//since 4.12.1.0 [W]
see also : getListFromWMI
EnvVar (
<environment variable> ) : string
[W/L/M]
see also : EnvVar
getProfilesDirList : stringlist
listFiles (
which(
see also : which
runningAsAdmin : bool
runningOnUefi : bool
//since 4.11.4.3: true: if the running OS was booted in UEFI mode [W/L/M]
runningInPE : bool
//since 4.12.0.13: true: if the running OS is a Windows PE [W]
runningInWAnMode
isDriveReady(
<drive letter> ) : bool
runningWithGui : bool
//since 4.12.3.6: true: if the running OS with GUI (at Win+Mac always true)[M/L/W]
opsiservicecall and json Related functions [W/L/M]
jsonIsValid(
<jsonstr> ) : boolean
//since 4.11.6: [W/L/M]
see also : jsonIsValid
jsonIsArray(
see also : jsonIsArray
jsonIsObject(
see also : jsonIsObject
jsonAsObjectHasKey(
<jsonstr>,<keystr> ) : boolean
see also : jsonAsObjectHasKey
jsonAsArrayCountElements(
<jsonstr> ) : intstr
see also : jsonAsArrayCountElements
jsonAsObjectCountElements(
see also : jsonAsObjectCountElements
jsonAsArrayGetElementByIndex(
<jsonstr>, <indexstr> ) : jsonstring
see also : jsonAsArrayGetElementByIndex
jsonAsObjectGetValueByKey(
<jsonstr>, <keystr> ) : valuestring
see also : jsonAsObjectGetValueByKey
jsonAsObjectSetValueByKey(
<jsonstr>, <keystr>,<valuestring> ) : jsonstring
see also : jsonAsObjectSetValueByKey
jsonAsObjectSetStringtypeValueByKey(
see also : jsonAsObjectSetStringtypeValueByKey
jsonAsObjectDeleteByKey(
<jsonstr>, <keystr> ) : jsonstring
//since 4.11.6.4: [W/L/M]
see also : jsonAsObjectDeleteByKey
jsonAsArrayPutObjectByIndex(
<jsonstr>, <indexstr>, <objectstr> ) : jsonstring
see also : jsonAsArrayPutObjectByIndex
jsonAsArrayDeleteObjectByIndex(
see also : jsonAsArrayDeleteObjectByIndex
jsonAsArrayToStringList(
<jsonstr> ) : stringlist
see also : jsonAsArrayToStringList
jsonAsObjectGetKeyList(
jsonStringListToJsonArray(
<strlist> ) : jsonstr
see also : jsonAsObjectGetKeyList
convert2Jsonstr(
<string> )
//since 4.10.8.3
see also: OpsiServiceCall OpsiServiceCall [W/L/M]
see also : OpsiServiceCall and json Related functions
see also : OpsiServiceCall Sections
opsi related functions [W/L/M]
getProductMap : stringlist
<propname>,<default value> ) : stringlist
<PropertyName>, <DefaultValue> ) : string
[W/L/M]
setActionProgress
retrieveSection (
<section name> ) : stringlist
[W/L/M]
<string> ) : string
runningInWanMode
reloadProductList
Process and Script Related functions
Killtask
<process name> : noresult
[W/L/M]
see also : Killtask
ChangeDirectory
<directory> : noresult //since 4.11.2.6 [W/L/M]
GetProcessList : stringlist
processIsRunning(
<process name> ) : boolean
see also : processIsRunning
isProcessChildOf(<searchprocstr>, <parentprocstr>): bool
//since 4.12.4.35 [W/L/M]
see also : prim-section.adoc#isProcessChildOf
shellCall (
shellCall (
<command string> ) : noresult
shellCall (
powershellcall (
<commandstr> [,<access str>='sysnative' [,<policy bool str>='true']]) : stringlist (output)
powershellCall(
<commandstr> [,<access str>='sysnative' [,<policy bool str>='true'][, <optionstr> = '']]) : stringlist (output)
//since 4.12.4.28 [W]
see also : powershellCall_list
powershellcall (
<commandstr> [,<access str>='sysnative' [,<policy bool str>='true']]) : noresult
powershellCall(
<commandstr> [,<access str>='sysnative' [,<policy bool str>='true'][, <optionstr> = '']]) : noresult
powershellcall (
<commandstr> [,<access str>='sysnative' [,<policy bool str>='true']]) : string (exitcode)
powershellCall(
<commandstr> [,<access str>='sysnative' [,<policy bool str>='true'][, <optionstr> = '']]) : string (exitcode)
see also : powershellCall_str
<dos section name> ) : stringlist (output)
[W/L/M]
see also : getOutStreamFromSection see also : opsi-script-ShellScript-catchout
processCall(
[W/L/M]
includelog
<file name> <tail size> : noresult
includelog
waitForPackageLock(
<seconds timeout string>,<bool should we kill> ) : bool
//since 4.11.6.1 [L]
which(
see also : which
executeSection(
<string expr with section call> )
//since 4.12.3.9 [W/L/M]
see also : executeSection
see also: ExecWith sections ExecWith [W/L/M]
see also: Winbatch sections Winbatch [W/L/M]
Regular expression related functions [W/L/M]:
General Info: : Regular expression related functions
isRegexMatch(<string>, <pattern>) : boolean
//since 4.12.1
see also : isRegexMatch
getSubListByContainingRegex(<pattern>, <target list>) : stringlist
//since 4.12.1
see also : getSubListByContainingRegex
getSubListByContainingRegex(<pattern list>, <target list>) : stringlist
//since 4.12.1
getRegexMatchList(<pattern>, <target list>) : stringlist
//since 4.12.1
see also : getRegexMatchList
getRegexMatchList(<pattern list>, <target list>) : stringlist
//since 4.12.1
removeFromListByContainingRegex(<pattern>, <target list>) : stringlist
//since 4.12.1
see also : removeFromListByContainingRegex
removeFromListByContainingRegex(<pattern list>, <target list>) : stringlist
//since 4.12.1
stringReplaceRegex(<string>, <pattern>, <replacement string>) : string
//since 4.12.1
see also : stringReplaceRegex
stringReplaceRegexInList(<target list>, <pattern>, <replacement string>) : stringlist
//since 4.12.1
see also : stringReplaceRegexInList
Registry related functions [W]
getRegistryValue(
GetRegistrystringvalue("[key] var") : string
[W]
GetRegistryStringValue32 ("[key] var") : string
//since 4.10.8 [W]
GetRegistryStringValue64 ("[key] var") : string
//since 4.10.8 [W]
GetRegistryStringValueSysNative ("[key] var") : string
//since 4.10.8 [W]
<regkey> ) : stringlist
//since 4.11.3 [W]
//since 4.11.3 [W]
//since 4.11.3 [W]
getRegistryKeyList(
<regkey>, <access str> ) : stringlist
//since 4.11.3 [W]
//since 4.11.3 [W]
//since 4.11.3 [W]
getRegistryVarList(
//since 4.11.3 [W]
//since 4.11.3 [W]
//since 4.11.3 [W]
getRegistryVarMap(
RegKeyExists(
<regkey>[,<access str>]) : bool
RegVarExists(
<regkey>, <var str>[,<access str>]) : bool
see also: Registry [W]
see also : Registry-Sections
see also : 64 bit
String handling functions [W/L/M]
see also : string
splitString (
<string1>, <string2> ) : stringlist
[W/L/M]
<string> ) : stringlist
[W/L/M]
composeString (
<string list>, <Link> ) : string
[W/L/M]
takeString (
<index>, <list> ) : string
[W/L/M]
<list>,<search string> ) : string
[W/L/M]
getIndexFromListByContaining(
<list> : stringlist, <search string> : string )
: <number> : string //since 4.12.0.13 [W/L/M]
see also : getIndexFromListByContaining
contains(
<str>, <substr> ) : bool
see also : contains
isNumber(
<str> ) : bool
see also : isNumber
trim(
<string> ) : string
[W/L/M]
see also : trim
lower(
<string> ) : string
[W/L/M]
see also : lower
upper(
<string> )
[W/L/M]
see also : upper
unquote(
<string>,<quote-string> ) : string
see also : unquote
unquote2(
see also : unquote2
stringReplace(
<string>, <oldPattern>, <newPattern> ) : string
strLength(
<string> ) : string (number)
strPos(
<string>, <sub string> ) : string (numner)
see also : strPos
strPart(
<string>, <start pos>, <number of chars> ) : string
see also : strPart
getValue(
[W/L/M]
see also : getValue
getValueFromFile(
EscapeString:
<sequence of characters> : string
// [W/L/M]
see also : EscapeString
stringinput(
Stringlist handling functions [W/L/M]
see also : stringlist
getListContaining(
<list>,<search string> ) : stringlist
[W/L/M]
<list1>,<list2> ) : stringlist
count (
<list> ) : string (number)
[W/L/M]
see also : count
emptylist (
<list> ) : stringlist
for %
<identifier> % in
<list> do
see also : opsi-script-stringlist-iteration
createStringList (
<string0>, <string1> ,… ) : stringlist
[W/L/M]
reverse (
[W/L/M]
see also : reverse
getSubList (
<start index> : <end index>, <list> ) : stringlist
[W/L/M]
getSubListByMatch (
getSubListByMatch (
getSubListByKey (
getSubListByKey (
getKeyList (
<list> )
addtolist(
<list>,<string> ) : stringlist
addListToList(
<dest list>,<src list> ) : stringlist
reencodestrlist(
<search string> ,
<search list> ,
takeString (
[W/L/M]
[W/L/M]
see also : jsonStringListToJsonArray
splitString(
[W/L/M]
composeString(
[W/L/M]
getValue(
[W/L/M]
see also : getValue
setValueByKey(
//since 4.12.1
//since 4.12.1
//since 4.12.1
//since 4.12.1
//since 4.12.1
//since 4.12.1
//since 4.12.1
editmap(
see also : editmap
areListsEqual(
< strlist1>, <strlist2>, <flag> ) : boolean
see also : areListsEqual
[W/L/M]
Time / Date related functions [W/L/M]
sleepSeconds
breaks the program execution for <string> seconds. <string> has to represent an Integer Value
markTime
: noresult [W/L/M]
sets a time stamp for the current system time and logs it.
see also : markTime
getDiffTimeSec : string
timeStampAsFloatStr : string
(Floating Number - format: 'days.decimal days') //since 4.11.6 [W/L/M]
see also : timeStampAsFloatStr
Usercontext / loginscripts related functions [W]:
GetUserSID(
<Windows Username> ) : string
GetLoggedInUser : string
//since 4.11.1.2
GetUsercontext : string
//since 4.11.1.2
GetScriptMode : string
see also : GetScriptMode
saveVersionToProfile : noresult
readVersionFromProfile : string
scriptWasExecutedBefore : boolean
see also : opsi-script-xml2-functions
getXml2DocumentFromFile(
<path to xml file> ) : xml2stringlist
//since 4.12.1
see also : getXml2DocumentFromFile
getXml2Document(
<stringlist wit xml> ) : xml2stringlist
//since 4.12.1
xml2GetFirstChildNodeByName(
<xml2stringlist>, <node name str> ) : xml2stringlist
//since 4.12.1.
see also : xml2GetFirstChildNodeByName
getXml2UniqueChildnodeByName(
//since 4.12.1.
see also : getXml2UniqueChildnodeByName
getXml2AttributeValueByKey(
<xml2stringlist>, <attr name str> ) : string
//since 4.12.1.
see also : getXml2AttributeValueByKey
getXml2Text(
<xml2stringlist> ) : string
//since 4.12.1.
see also : getXml2Text
see also : XML2 Sections [W/L/M]
TOML files related functions [W/L/M]:
see also : opsi-script-toml-functions
LoadTOMLFile(
//since 4.12.5
ReadTOMLFile(
//since 4.12.5
//since 4.12.5
GetTOMLAsString(
//since 4.12.5
GetTOMLKeys(
//since 4.12.5
GetTOMLTableNames(
//since 4.12.5
GetTOMLTable(
//since 4.12.5
//since 4.12.5
GetValueFromTOML(
//since 4.12.5
ModifyTOML(
//since 4.12.5
//since 4.12.5
SaveToTOMLFile(
<TOMLcontents: String> , <TOML file Path: String> ) : boolean
//since 4.12.5
ConvertTOMLtoJSON(
//since 4.12.5
<TOMLfilePath: String> , <JSONfilePath: String> ) : boolean
//since 4.12.5
