Installing the minimal Linux opsi products
To distribute software with opsi, ready-made products are available for installation. These include the agent ('opsi-client-agent'), which must be installed on the clients for management.
There is an automated and a manual way to do this. The automated option is recommended.
Automatic installation of the minimal Linux opsi products
For the automatic installation of the opsi products there is the tool opsi-package-updater, which configured as in '/etc/opsi/opsi-package-updater.conf' or /etc/opsi/package-updater.repos.d/, automatically fetches the current packages from the opsi repository and installs them on the server.
The configuration of the opsi repository for Windows clients can be found in the directory /etc/opsi/package-updater.repos.d/ in the file uib-linux.repo.
Activate the desired repository by setting the entry active = true in the desired *.repo file.
/etc/opsi/package-updater.repos.d/uib-linux.repo; This repository provides products for deploying and managing Linux
; clients with opsi.
[repository_uib_linux]
description = opsi Linux Support
active = true
baseUrl = http://download.uib.de
dirs = opsi4.2/stable/packages/linux/localboot/, opsi4.2/stable/packages/linux/netboot/
autoInstall = false
autoUpdate = true
autoSetup = false
; Set Proxy handler like: http://<address>:8080
proxy =
Install the packages on the server by running this command as root:
opsi-package-updater -v --repo uib_linux install
After a successful installation you have to reload all data in opsi-configed so that the new products are visible there.
If the connection to the Internet has to be routed via a proxy, this must be entered in the .repo configuration files in /etc/opsi/package-updater.repos.d/ as the value for proxy.
From version 4.1.1.33 of opsi-utils a global proxy can be configured in /etc/opsi/opsi-package-updater.conf.
proxy =
If the installed packages are to be updated later, this can be linuxed with the following command:
opsi-package-updater -v update
Further information on opsi-package-updater can be found in the manual.
Manual installation of the Linux opsi products
There is also the option of downloading and installing the packages manually.
Get the current opsi packages in the .opsi-package format.
You can find the packages at https://download.uib.de/opsi4.2/stable/packages/linux/localboot
and at https://download.uib.de/opsi4.2/stable/packages/linux/netboot.
We recommend saving the .opsi files under /var/lib/opsi/repository.
To ensure that the process opsiconfd can access the files, you should run opsi-set-rights /var/lib/opsi/repository.
After downloading you have to install the packages on the server with the command opsi-package-manager -i <packagename>.opsi.
