Introduction
The open source program opsi-script (former at windows 'opsi-winst') serves in the context of OPSI - Open System Integration (cf. www.opsi.org) – as the central function for initiating and performing the automatic software installation. It may also be used stand alone as a tool for setup programs for any piece of software.
opsi-script is basically an interpreter for a specific, rather simple script language which can be used to express all relevant elements of a software installation.
A software installation that is described by a opsi-script script and performed by executing the script has several advantages compared with installations that are managed by a group of shell commands (e. g. copy etc.):
  • opsi-script can log very thoroughly all operations of the installation process. The support team can check the logfiles, and then easily detect when errors occurred or other problematic circumstances unfold.
  • Copy actions can be configured with a great variety of options if existing files should be overwritten
  • Especially, it may be configured to copy files depending on their internal version.
  • There are different modes to write to the Windows registry:
    • overwrite existing values
    • write only when no value exists
    • append a value to an existing value.
  • The Windows registry can be patched for all users which exist on a work station (including the default user, which is used as prototype for further users).
  • There is a sophisticated syntax for an integrated patching of XML configuration files.
